OT: DIY, Stripped threads
Hi
Looked at the DIY forums, and I guess they're closed as I'm not allowed to post there. I have a problem with my mother-in-law's car's transmission pan. It's leaking a little, and I discovered that two of the bolts will not seat. The bolts are M8x16, pitch 1.25.
How to repair? Longer bolt? Tap to what? Any other suggestions?
Hi
Next would be drilling out the hole and either tapping up one size or using a thread insert (heli-coil) which brings you back to the original size.
There is plenty of info if you do an internet search.
