Half-shaft removal
Basic Site Sponsor
Basic Site Sponsor
Half-shaft removal
I need to know if the half-shafts can be removed directly from a 996 GT3 or is there some suspension disassembly required? TIA.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Larry,
I hope this is helpfull. It comes out of the workshop manual for the 996. In general when there are differences for the GT3 they are noted. There were no additional notes in this case.
Hank
42 Rear wheel suspension, drive shafts 911 Carrera (996)
Removing and installing right drive shaft (manual transmission)
Note
The available space for drive shaft removal and
installation varies depending on the transmission
type and the side of the vehicle. The removal
and installation description is therefore
subdivided into:
Right drive shaft - manual transmission
left drive shaft - manual transmission
Removing right drive shaft
1. Raise vehicle and remove wheel.
2. Undo axle nut.
3. Slide a suitable protector (e.g. plastic tube,
old coolant hose - 0 approx. 30 mm) over the
d rive shaft.
Undo the drive shaft on the transmission
flange.
42210008
4. Remove stabilizer mount on the stabilizer.
5. Remove right spring strut, see
Servo No. 427119.
6. Lift the wheel carrier until the drive shaft can
be pulled out to the rear. Observe following
note!
Note
Lift the wheel carrier using a universal lift placed
at a suitable point. Place a hard rubber pad
between the universal lift and wheel suspension
so that it cannot slip. Ensure proper seating and
carefully lift the wheel suspension.
(Illustration shows the left side) 42520001
42 - 32 42 21 19 Removing and installing drive shaft (manual transmission)
9964231 Printed in Germany - 39, 2000
911 Carrera (996) Rear wheel suspension, drive shafts 42
7. Press drive shaft out of the wheel hub
toothing.
Installing right drive shaft
Install in reverse order. Grease the toothing
of the drive shaft with OptimolyHT.
Note
Since the drive shaft can be moved only using
great force, loosen the shaft inwards with taps
on a copper mandrel. Lift up the shaft near the
inner joint (possible damage to the closure cap
of the drive shaft may occur).
For unfavourable tolerances, the drive shaft
must be pressed out of the wheel-hub toothing
using a universal wheel-hub extractor.
Always check the boots for damage if continuing
to use the drive shaft!
Replace the boots if necessary.
Carry out a visual inspection of all parts.
Replace self-locking nuts.
Use correct tightening torques.
Note
When installing the spring strut, make sure that
the spring-strut fastening screw (arrow) is
tightened only in vehicle position.
Vehicle position means: Vehicle standing on the
wheels, or the wheel suspension is being raised
with a universal lift.
42210004
180_97
8. Remove the drive shaft. To do this, take the
drive shaft on the transmission out in
rearward and downward direction.
Printed in Germany - 39, 2000 9964231
42 - 33
Removing and installing left drive shaft (manual transmission)
Removing left drive shaft
1. Raise vehicle and remove wheel. Note
2. Undo fastening nut at the outside of the drive
shaft.
Place a hard rubber pad between the universal
lift and wheel suspension so that it cannot slip.
Ensure proper seating and carefully lift the
wheel suspension.
drive shaft.
Undothe drive shaft on the transmission
flange.
4. Remove the rear underbody cover (5).
42520001
691_96
5. Compress the wheel carrier (50...60 mm).
42 - 35
6. Press drive shaft out of the wheel-hub toothing.
Note
(Fig. 42210004).
(Figure shows the right-hand side) 42210004
7. Remove drive shaft. To do this, pullout the
drive shaft over the transverse strut to the
front and downward (arrows).
42210009
Installing left drive shaft
Grease the toothing of the drive shaft with
Optimoly HT.
Note
Only optimised axle nuts for drive-shaftfastening
are available from the Parts Service.
Pictures and text can be found under the
installation instructions for the right drive shaft.
42 - 36 42 21 19 Removing and installing drive shaft (manual transmission)
Hank
Note
subdivided into:
2. Undo axle nut.
d rive shaft.
flange.
42210008
Servo No. 427119.
note!
Note
toothing.
Note
Note
42210004
180_97
42 - 33
shaft.
wheel suspension.
drive shaft.
flange.
42520001
691_96
42 - 35
Note
(Fig. 42210004).
42210009
Optimoly HT.
Note
The description from the manual is right on. I repacked my axles this spring, and I found that removing both shafts took about two hours - one hour of which was just trying to get the suspension lifted to just the right height to be able to wiggle the shafts out of the car. Reinstalling the shafts took less time (the opposite of what I expected) - maybe an hour to install.
Make sure you use the thread compound on the hub when reinstalling. It's a metal paste that keeps the hub and hub nut from fusing. As I recall, the torque on the hub nut is 300 to 320 lb/ft, so you'll need a very long, good torque wrench to reinstall. Borrowing a friend's if you don't have one makes sense here.
Jim
Jim
looks like there are two tubes...one grease and one sealer....see attached
part #s 000 043 110 00 and 000 043 205 36
In the text they say "Grease the toothing of the drive shaft with
Optimoly HT". Is that either one of these?
