Anyone use Redline Oil 75W90 NS in thier transmission?
I just got off the phone with Redline Oil. They recommended their 75W90 NS oil for the G50/G96 transaxle.
Anyone tried this? Results?
Andy
75W90 NS
This GL-5-type geal oil doesn't contain the friction modifiers for limited-slip hypoid differentials. This makes the transmission synchronizers come to equal speeds more quickly, allowing faster shifting and much easier low-temperature shifting. Can also be used in racing limited-slip differentials where weak spring design causes too much wheel spin.
Andy
75W90 NS
Been using it in my cup car for 4 years...works great, no issues. LSD is working fine and has not yet had a clutch pack rebuild...probably just put a curse on it. also used Mobilube SHC at times. either will be fine.
