996 GT2/GT3 Forum 1999-2005
Steel Synchros
Old 11-05-2007, 08:56 PM
Boulder GT3
Boulder GT3's Avatar
Default Steel Synchros
The GT3 has steel synchros for durability I assume. 911's other than the GT2/3have softer bronze alloy synchros because they shift smoother or are quieter I assume. Does a GT3 shift more notchy and are my assumptions correct?
I can't tell the differance between the two transaxles in actual driving and I wonder why they don't just put steel synchros in all of them if they are more durable?
As an aside, the aftermarket needle bearing linkage ends make a huge differance in the way the box feels.
Old 11-05-2007, 09:48 PM
iLLM3
iLLM3's Avatar
To be honest, I don't feel much of a difference between my GT2 with stock shifter kit and 996TT with the short shifter! BUT that can say something, GT2 stock feels like 996tt with short shifter, so that would mean yes its notchy/direct stock ...
Old 11-05-2007, 11:47 PM
Jager
Jager's Avatar
GT3 tranny is "notchy" but precise. On the blip double clutch, the compression of engine and tranny from the blip work so beautifully together that the tranny slides into the lower gear with precision and finality. It's very positive, much more than the Carrera tranny. I love the GT3 tranny. But it can be notchy in upshifts too, which is a bit wierd.
Old 11-06-2007, 01:35 AM
Moogle
Moogle's Avatar
The steel synchros are only on the 3-6
1/2 both have brass only.
Old 11-06-2007, 06:59 PM
spenny_b
spenny_b's Avatar
And on the Mk1 GT3 (which of course you didn't get in the US), none of the 6 gears had steel synchros.....common upgrade to the Mk1 'boxs when rebuild time though.
Old 11-06-2007, 07:36 PM
Boulder GT3
Any thoughts on why not to put steel in the other 911's?
Old 11-06-2007, 10:18 PM
Moogle
Moogle's Avatar
IIRC, the 997 has all steel now.
Old 11-07-2007, 01:56 PM
fhp911
fhp911's Avatar
I'd appreciate an education on this subject.
What's good/bad about steel/brass, why do we have steel on some gears but not others, etc?
Comments, anyone?
Old 11-07-2007, 03:41 PM
dan212
dan212's Avatar
Default Brass is softer than Steel
Brass is softer than Steel. So my guess is that the brass synchros will feel a little smoother/softer/less notchy - at but the expense of wear. Porsche says that the standard 6 speed 997 transmissions are now more durable because they switched from brass to steel synchros.
Old 11-07-2007, 04:03 PM
Moogle
Moogle's Avatar
Also: on the 997 GT3 there are now carbon coatings on the first 3 synchros in addition to having all steel synchros.
Old 11-07-2007, 04:16 PM
SpeedGeek
SpeedGeek's Avatar
The 997 Carreras use a new box from the Japanese company Aisin. Does anyone know if this is also true for the 997 GT3s, or do they still use the Getrag unit?
Quick Reply: Steel Synchros
