CUP center radiator airduct
Hi all,
I need some help with my project. I want to re-angle my center radiator, like the CUP car, and wonder if anyone here have any pictures/information on the center airduct. I ordered mine from Gert but it's in two pieces. I've attached two pictures of the parts, which looks kind of weird. No matter how I play with them they just don't seem right.
So far I already received the following parts:
1) 48mm Aluminum spacers
2) Hex collar screws M8x65
3) CUP radiator supply hose
4) CUP radiator return hose
5) The center airduct in question!
While I'm at it are there any other parts I need for this project?
Any help would by appreciated. Thanks in advance.
Hi ltcjmramos,
I've search the forum and have found some info. mostly to do with cutting the slits on the bumper cover. I have also found a thread with regards to the hoses, which I think I have the correct ones. However, I have not found any information on the airduct that's required and want to get some pictures and if possible more info. The pictures of the airduct I got from Gert looks a bit off and I just want some clarification. I would have thought that the airduct should be one piece not two!
Here's the thread I have referred to in the past.
I thought about doing this mod too, but haven't....yet. The duct you have doesn't look right. Check out the thread & diagram below.
https://rennlist.com/forums/showthre...ght=front+duct
https://rennlist.com/forums/showthre...S+radiator+mod
go to page 2 and viperbob outlines what you need from the cup version.
Also found this one w/ a picture of the radiator hoses.
