32:8, short gear box GT3 MK2
Location: Brussels, Belgium, 1 hour West of Spa, 2 hours West of the Ring ;-)
1 Post
Depends on the track. You may find that you have to shift in the middle of a fast corner or just yards before braking or change your driving style. Still, I have done the upgrade on my MK1 and I'm liking it more and more.
I have it on the GT3. I think for most tracks you would be better off changing the upper gears. My home track used to be gears 2 , 3, 4. Now its 3 ,4 5. ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Some corners are better geared while others are worse. Net result is a wash. Do the gears. Supposedly more maintenance but the result is better.
The gear gap between 2nd and 3rd is too wide, really bad. The 3rd/4th is closer but it could be better. The 4th/5th and 5th/6th are perfect.
In my case, the RSR R&P eliminated the use of second gear on most tracks. My engine stays on the strong power band for longer.
Re-gearing is ok as long as the turns at your local tracks are above 65 mph, otherwise you will have to re-gear and install a short R&P, because the stock 2nd gear is too long (84mph).
