NEW LSD NEEDED : 04 CUP ? GUARD ? NEW CLUTCH PACK ?
My 2003 GT3 LSD is gone. I need to consider it's replacement or upgrade..
I have read different threads ( Phokaioglaukos, mds, Mike K, Shock Doctor). It seems that there are different options:
1.- Replacing the original clutch pack ( My shop will charge aprx 400 $) It seems to be the less durable solution.
2.- Installing the 04GT3 CUP LSD
3.- Guards LSD ( Which seems more difficult , and expensive for a non US resident)
I use it 95% track ( with Slicks ) BUT I do not want to make it undrivable on the streets..
Any suggestions ?
Thanks in advance to you all for your - allways good - advise
Any suggestions ?
Hi
I think you need to think about suspension, drive shafts, LSD, clutch flywheel, gearbox, final drive as a system.
In the mean time, you may be able to just replace the metal shims in the stock LSD, this will give you time to work out what to do long term, it isn't a solution.
It is entirely possible that you are now placing strains on the LSD that are quite severe. In your shoes I would use the winter to systematically upgrade the suspension/transmission. If you work out what you want to end up with first, this will stop you wasting time on parts that are not suitable.
You need your car to be bullet proof, with a little planning that can be possible.
Good luck.
R+C
Good luck.
R+C
The Gaurd unit is what alot of the top teams (Alex Job, Orbit Racing, TRG etc) are replacing the factory LSD with due to its superior performance.
I replaced the factory LSD with a Gaurds unit with specific lockups and have been very happy.
As you said not cheap but as I was upgrading the whole system on my car I felt it was worth the effort.
Eddie
Just replacing the LSD is not addressing any problems, unfortunately. I believe he has to look at everything, suspension components, driveshafts, alignment, stronger drive train elements, mountings.....
If te LSD was relaced and nothing else touched, I'd expect more problems.
R+C
R+C
Eddie
R+C
R+C
That's why I mentioned that I did it as part of my overall upgrade to the car..
BTW, How's your GF's track car comming along? Any pictures?
the LSD crack-up is a symptom of putting the suspension under high levels of stress. Sure, you can fix the LSD, and it will go again, or another bit will fail. The more reliable the car is the more fun time there will be on the track. The car is in the process of being modified beyond 'road legal', so best to avoid a 'bandaid' approach to fixing problems. How to make a GT3 a reliable track car is well understood.
R+C
Eddie
Its still in 'road-trim', and getting better, unfortunately, weaning a girl off a Ducati is quite hard. I am presently trying to work out a way forward for the gearbox, the numbers 6012 loom large, I'm watching the MPower and Alzen Cayman race cars in the VLN, one of our guys is on the drive team in 9 days time.
Driveline problems appear to be common. If we switch to a 8012, or the race original therof, we have quite a lot of tricky work, but it will be worth doing, and we could make it 'clacky-paddle' as the saucy minx puts it.
This proper transaxle has lots of benefits, proven in 24 hour racing, tough as nails, better weight distribution, easier to protect from damage in racing incidents, easier to change gears, integrated LSD, potential to get 'very trick'.
In many respects I feel like I am back sailing, its all about air management. I have to get a lot of air into the kind of space a moonshiner would fill with whiskey.
Good news is that we have unobtainium carbonish brakes that are going through the TÜV process. These look like being really special, we think we have found suitable pad material for road as well as race use. However, from a cost viewpoint they make whatever Ferrari, let alone Porsche use, look like Walmart bargains.
Pictures are still embargoed.
R+C
R+C
They just swap the plates for more robust ones. You can wear out a GT3 diff just using MPSCs, so I don't really see why you can't just drop the cup one in if you are doing that without worrying about everything else. It has higher locking though, so will obviously affect the balance of the car.
one of our guys reversed the LSD and had a fun practice session driving different lines to everybody else, before he switched it back.
one day somebody with time on their hands is going to fit the GKN Italy sourced LSD from the M3 in the GT3, that is an impre3ssive unit, as is the kit in the F430.
if buying a new diff, I'd look beyond the cup component.
R+C
