Alignment results
Originally Posted by rbarna
street tires with this config. Can I dial in camber while at the track by using a pyrometer to guess and check? Or do I need an alignment rig?
Let's say that your pyro shows the inner edges of the fronts heating up... is that a camber or toe issue???
Personally, I wouldn't mess with it. Learn the platform the way you have it setup now... after that, it simply becomes a matter of how much $$$ you wish to spend at the race shop.
