GT3 + steep driveway = question
#47
Originally Posted by Lori
How about angled concrete bumps with long 2"x6" runners in front for the car to sit on in the garage?
michaeldorian (10-19-2021)
#48
There is a much easier solution to this problem... remove the partition in the garage door, make it a single wide door. That will give you the ability to approach at an angle as you enter the garage, the same as at the bottom of the driveway when you enter from the street.
#49
Frayed, thanks! I was close to giving up there. As I said, I think I'll need to get some wood and experiment with the 335. If I can figure that out, I can probably work it out. The concavity at the bottom of the driveway is bad enough to scrape a bit, but not as bad as I was picturing it. I might be able to live with it, or overcome it with one well-placed block.
AndyT, I'm in Staten Island, on the north shore right next to the ferry terminal.
#50
#51
#52
I gave up with the front lip on my '04 GT3. Yes -- the driveway ripped it off a few times, but so did potholes and parking lots. No effort to fix my driveway would cure the other problems.
So I removed the lip and -- presto !! -- no more problems. I do track my car; maybe there is some high speed understeer which the lip would cure but I don't notice it.
I'm just back from 2 glorious days at Watkins Glen, where I was more than adequately fast and I had plenty of front-end grip.
So I say the front lip is somewhat a fashion statement which I can live without. (especially since I don't have a choice -- whenever I re-affix it, within a few days it is ripped offf again.)
#53
I think you should hire an architect first. He can tell you what you can and can't do and maybe has seen situations like this.
