RMS leak
RMS leak
I recently had my rear main seal replaced under warranty and it leaks worse now then it did before the swap. If left for a week it will probadly leak several drops. What is the accepted norm for this?
Thanks for the input.
Dean
Dean
Dean
Dean
Had my car inspected, by a PCA authorized independent mechanic, for DE and was told of a "slight" RMS leak. Came as a big surprise(28K miles), not even a drop where the car is garaged. I was told that the new 997 seal is probably the way to go. I believe I read in a previous thread that the Cayenne RMS was better as well. Any thoughts?
BTW Arctic Fox, as per my mechanic, your days are numbered. He claims that almost all eventually will need an RMS issue.
My RMS has a very slight leak. More seepage than a leak since there are no drops on the floor. I took it to the dealer and was told it needs to have drips to be covered. My warranty expires next Feb so I imagine I'll see a drop of oil on the floor in March.
The motors are apples-and-oranges between the two.
Originally Posted by Holger B
May be true for the 996, but not GT3's.
I would imagine the configuration between the two to be somewhat similar. Why does the GT3 seem more immune? Thicker seal, alignment????
I've had the RMS leak fixed twice. The first time it was fixed with the standard part, the repair held for two weeks. The second time it was repaired with a spring tensioned 993 RMS, been dry ever since.
The similarities end once you get past the flat-6 configuration. Try a search for more details on the differences. Any engine can develope an RMS leak.
The problem with a seal leaking is probably one of two "more common" problems that seems to be the status quo of explanations......in the non GT/TT 996's cars the case could have an alignment problem that was design created and not something that could be "corrected" and NO repacement seal was ever going to fix that so engine replacement was a need. The more common reason it didn't hold was that the installer SCREWED up the install (which seems to be common these days). If they are not using the "proper and most updated" RMS install tool then it is hit or miss with a proper install.
FYI....65K miles of RMS free driving in my CAB and 25K in the GT3
Originally Posted by jeeva
This doesn't sound right at all. Usually it is the dealer who see the seepage and recommend a change under warranty. AFAIK, it doesn't have to be a leak. I would try to get it replaced under warranty.
The use of thin synthetic oils are also a big contributer to seal leaks in almost ever make car on the road. Most leaking seals I have seen, BMW Lexus, Porsche, etc, have been reduced and/or eliminated by either adding a better viscosity synthetic oil, adding a quart of good dino oil to the cranckcase, or a seal conditioner additive to the oil.
Until the oil manufacturers find the key to making syntehtic oil so it will properly keep to the seals soft and plyable, leaks will continue to occur more than they need to for people using thin synthetics. Castrol oil has less of a problem than does Mobil 1.
