996 gt2 transmission problem
Hi,could someone please help me with diagnosing/resolving the problem with my trans.my car has 14000 miles and the 2nd gear slips into neutral under de-celleration mostly on downhills.It never does it at all times and never does under accelleration.The gear change is smooth.I am hoping it is adjustment,any advice?
380381
380381
Wow now this is interesting, here is a huge sticky thread on 6speed about the infamous "2nd gear popout" issue , that has been unheard of on the GT2's but a common issue on some early model 996TT's, very strange.. Costs are great and it gets worse, under warranty they sometimes replace it and its over 10 grand for the transmission replacement i believe! Goodluck
http://6speedonline.com/forums/showthread.php?t=60061
996-300-020-CX $8292.80 (MSRP)
Overload of dual-cone synchronization 1st/2nd gear
Symptoms; Grinding when shifting 1st/2nd gear, hard shifting 1st/2nd gear
The synchronization teeth of the gear have become rounded.
The synchronization components (synchronizing, tapered and friction rings) do not display excessive wear.
The teeth of the shift collar have become rounded, similar to the teeth shown in the first image.
If the damage described is diagnosed on a transmission, it is very likely to be caused by an assembly fault. This fault causes the gearwheel to become loose and therefore causing the "popping out of gear" condition.
This fault only occurs on transmissions up to the following numbers:
911 Turbo (996), number 6530 and 911 GT2 (996), number 2100
Hi,Jason
Thanks for the info.Just a few more details,my change from 1st to 2nd & 2nd to 1st is smooth with no grinding or hard shifting.Will the shift cable adjustment not also cause 4th & 6th to also do the same thing?All gears feel the same when shifted,out of 10 tries 2nd gear will pop out maybe twice on a downhill with no gas being fed.Will appreciate any further advice.
Rajen
Rajen
Hi,Jason
Rajen
Rajen
iLLM3
Thanks,i did read it and i think i am trying to unsucessfully convince myself that the problem is not as bad.I spoke to my local porsche agent and they will not even consider the claim because of the rev info on the computer,i think that they are aware of the history on these boxes and are using the info to get out of their obligation.Similar experiences had by some of the individuals on your link
Rajen
Rajen
I have learnt to drive and tracked my 993 RS for 5yrs,and after doing 1500miles on the GT2 they tell me i have been changing gears at revs &speeds that are too high.the 993RS is doing 40000 miles, most of it track and the box is still as good as new.I thought that the GT2 was a track version of the turbo but looking at the history on these boxes they failed miserably and left the owners to fit the bill for their poor design.
Rajen
Rajen
Originally Posted by lightguy
Why would your rev info be linked to a transmission problem ?
Porsche used to be "The good guys".
'The good guys" are of the past ...Look up all the factory deficiencies ( ie Gen 1 PCCB concerns )that they have walked away from.
Had a similar problem with my 1st gear going back to nuetral last year.Luckily my car is still under factory warranty. Got me a brand new transmission and diff under warranty. All I had to pay was $1100 for a new clutch. It was not worn about 60% left but what the heck. its free
