GT3 15K service cost?
I'm looking at a car that has 14K miles.
The first service is so close I was wondering how much it runs on a GT3 and should I factor that into the purchase price?
Thanks.
Thanks.
This is what we do:
Run engine diagnostics.
Replace engine oil, seal ring and filter.
Particle filter, replace filter element.
Vehicle underside and engine compartment, visual inspection for leaks (oils & fluids) and chafing damage (lines & hoses)
Power assisted steering, check fluid level.
Coolant hoses: check condition, Radiators: visual inspection for external contamination, Coolant: check the level and antifreeze protection.
Brakes hoses & lines: Visual inspection for damage, routing and corrosion. Check brake fluid level.
Drive shafts: Visual inspection of the boots for leaks and damage.
Tires & spare wheel: check the condition and tire pressure.
Vehicle lighting: check function and adjustment.
Windshield washer system, headlight washer: check fluid level and nozzle settings.
All other electrical equipment and warning and indicator lights,: check function.
Brake pad & rotor inspection.
Check poly rib belt.
Road Test: Foot and parking brakes, engine, clutch, transmission, automatic speed control, steering, heating, a/c system and instruments: check function.
Consultation
Consultation
Originally Posted by Laura
This is what we do:
Consultation
Consultation
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
"About $225, but I would also advise to add a brake flush, strongly suggested every 2 years at a minimum. (More if a track car)"
That's really inexpensive. I had a 2-yr service done (including a change in brake fluid) at my dealer. They charged me $743. I even provided my owm Mobil one
GT3 player par excellence
laura, hergenshiemer needs to have a shop up in northern ca.
i will make sure you get enough customers to be worthwhile.
so when are you moving up?
Do I still need a brake flush if my '04 GT3 only has 2,000 miles? Yeap, mine is a garage queen so it's only driven few times a month
For street use, you need to replace the brake fluid every 2 yrs, regardless of milage. You may wish to review your maintenance book. It is on page 9
yes replace brk fluid every two years even if you dont drive it. the oil will suck up moisture in air and reduce boiling point. it probably doesnt really matter, but it's cheap insurance so why not.
Thanks! I have to bring mine in for the 2nd oil change next week anyways so i will have them flush it as well. How much do you guys normally pay for a brake flush? I took mine to Pacific last year for it's first oil change and it was $230 and this time the estimate is $265, i hope it doesn't go up $35 every year
