Rubber or Metal Valve Stems???
No TPMS in my GT3. I assume that I can install the stems PRIOR to taking the wheels to Discount Tire to install the tires since the wheels are without tires right now??? If so, is there a "torque" spec for them or just "hand-tight", etc.?
Thanks!
Thanks!
Technical Guru
Originally Posted by LVDell
I assume the 993 p/n stems are the ones I need to order correct?
Thanks Jason. If I interpret your post correctly you are saying that there is NO metal valve stems available for the non-TT wheels? Just rubber?
I had a feeling I would need to outsource the stems from a non-Porsche parts counter.
