GT3 Running Rough: Durametric Output Logs
Originally Posted by 1999Porsche911
I believe there is a maximum number of #1 over revs reported by the compouter. Something like 655,000 or so. Next time I get there, I'll let you know. Mine has aready reset to ZERO a few times.
Just teasing !
I have about 18,000 range 1 and I was a little worried that it was getting a little high but, I guess I have a long way to go. My home track has a few stretches that make bouncing off the limiter necessary to be quicker. I won't feel guilty about it anymore.
Originally Posted by Mike K.
You mean you have over 655,000 range 1 over revs ? Or you have reset the computer.
Originally Posted by JasonAndreas
The range (X) overrevs are probably stored as 16-bit integers so the maximum number would be 2^16 = 65536.
My statement was tongue in cheek.
You know, I forgot to follow up on this thread. Thanks for reminding me!
I took it to the local PCar dealer back in March. They fixed it under warranty, and I remember their work order charged Porsche $222. I just looked at my invoice, and they note the following:
*replaced camshaft variable timing solenoid
*replaced vario cam valve (996-105-303-71)
Everything has worked fine since...
Good luck!
-B
Good luck!
-B
Just picked up my car this past Wednesday, July 11th. Wow, what a wait!!
A VarioCam Actuator had to be replaced in the right bank. The engine had to be removed to make the repair (not a big deal in a 911) and the part had to be ordered from Germany. Apparently it had to be manufactured as there was no stock. This took 2.5 weeks. Diagnosing the problem with Porsche and making the final fix added 3 more weeks.
All was covered under warranty. The dealer was still figuring out the bill but, for obvious reasons, he wanted me to get my car to me, so I don't know all the bits that went into the repair.
So far I have only run it up to 8000 rpm in 2nd gear and it appears to be as good as new!! Will know for sure when I take it to Calabogie on Monday.
996, 99610530371, adjustment, boxster, camshaft, diagnostic, durametric, erase, gt3, p1341, porsche, range, rev, rough, running
