Has anyoned installed a brake proportioning valve?
Instead of going with the expensive adjustable brake-bias from the cockpit, a valve can be installed out of the ABS module on the front brake lines.
Once installed, the ABS fuse has to be taken out, to adjust the proportioning valve. Adjust the valve so the rear wheels lock before the front ones, then dial a little of front bias, plug the ABS fuse and enjoy.
I know from one GT2 that got it done, but I can't find his contact information. He's on the Left Coast.
