GT3 RS badge
#32
These guys have some amazing cars...too bad thay are so far away..
http://www.gmundcars.com/cars/453/996gt3rs.html
#33
#34
Ok....so was it an option on the RS as well? All the RS pics I have seen were none xenon.
#35
Technical Guru
Originally Posted by mooty
if you are indeed SERIOULY considering doing a REAL RS, just buy thusly's car. you will not even come close to an RS for less than $150k.
#36
Mine has them (Bi-xenon).
Saves weight vs the lithronic's. Approx 5kg's.
#37
quite a few opinions on the rebadge...thank you all for your perspectives it has changed my mind. i'm a fanatic and love my GT3. I want to morph it toward an RS or Cup and am working with Jeff Gamroth of Rothsport. He builds Porsche race cars and is considered an expert. He figures it will take about $20k USD to get it to be a considerable "weapon". I am backing off of putting the RS badge on my GT3 because you are all correct, it will take a lot more to make it spot on to RS specs and the last thing I want to project is "racer-boy". I just want to improve what I already have so I really don't want to "fake" it. For me it is not about impressing anyone, it is all about the car and making it better....slowly.
Thank you all for your opinions and please know that I think I "get it".
Andrew.
Andrew.
#38
Technical Guru
Code:
Item Number Quantity Description Unit Cos Amount 996-102-017-95 1 pulley 63.14 63.14 964-102-239-31 1 flywheel 412.71 412.71 964-114-143-31 1 starter ring gear 134.11 134.11 996-341-117-92 1 brake cooling spoiler (L) 115.89 115.89 996-341-118-92 1 brake cooling spoiler (R) 109.76 109.76 996-341-157-92 1 wheel carrier (L) 505.06 505.06 996-341-158-92 1 wheel carrier (R) 505.06 505.06 996-341-321-71 1 support for ABS cable speed sensor 15.59 15.59 996-341-322-71 1 support for ABS cable speed sensor 15.59 15.59 996-606-235-91 1 heat protection for speed sensor ( 11.68 11.68 996-606-236-91 1 heat protection for speed sensor ( 11.68 11.68 996-341-661-90 2 cover 38.38 2 999-217-042-09 12 hex-head bolt M8 x 35 0.89 10.68 996-343-041-97 2 shock absorber 286.7 573.4 996-343-531-97-50 1 coil spring set 115.9 115.9 996-343-070-93 2 swaybar droplink 85.4 170.8 996-347-804-91 1 steering wheel (blue) 441.93 441.93 996-331-111-90 1 rear wheel carrier (L) 559.96 559.96 996-331-112-90 1 rear wheel carrier (R) 559.96 559.96 996-341-661-90 2 cover 38.38 76.76 999-217-042-09 12 hex-head bolt M8 x 35 0.89 10.68 996-341-121-90 1 control arm (L) 181.78 181.78 996-341-122-90 1 control arm (R) 181.78 181.78 900-076-025-02 2 hex nut M8 0.13 0.26 999-025-269-02 2 washer 8.5 x 17 x 6 3.06 6.12 996-341-441-90 2 bearing flange control arm 59.79 119.58 996-331-551-90 1 support 32.2 32.2 996-331-051-92 1 rear axle side section bracket (L) 662.45 662.45 996-331-052-92 1 rear axle side section bracket (R) 662.45 662.45 996-333-051-97 2 shock absorber 300.43 600.86 996-362-136-09 2 front wheel 8.5 x 18 (BLUE) 1024.78 2049.56 996-362-142-09 2 rear wheel 11 x 18 (BLUE) 1085.78 2171.56 996-361-303-94 4 hub cap (BLUE) 11.59 46.36 996-351-801-90 1 rotor protective plate upper (L) 20.21 20.21 996-351-813-90 1 rotor protective plate lower (L) 20.21 20.21 996-351-815-90 1 air baffle (L) 20.21 20.21 996-351-802-90 1 rotor protective plate upper (R) 20.21 20.21 996-351-814-90 1 rotor protective plate lower (R) 20.21 20.21 996-351-816-90 1 air baffle (R) 20.21 20.21 996-352-801-90 1 rotor protective plate upper (L) 36.6 36.6 996-352-813-90 1 rotor protective plate lower (L) 36.6 36.6 996-352-802-90 1 rotor protective plate upper (R) 36.6 36.6 996-352-814-90 1 rotor protective plate lower (R) 36.6 36.6 996-355-503-91 1 rear brake line support (L) ------ 14.16 14.16 996-355-504-91 1 rear brake line support (R) ------ 14.16 14.16 996-424-075-92 1 gearshift **** (BLUE) 63.45 63.45 996-424-031-93 1 parking brake lever (BLUE) 280.6 280.6 996-545-111-92 1 rear window 720.39 720.39 996-545-521-04 1 sealing frame 35.13 35.13 996-545-545-01 1 trim frame 40.96 40.96 996-555-121-00-ES 1 door trim panel (L) 907.52 907.52 996-555-122-00-ES 1 door trim panel (R) 907.52 907.52 996-552-109-00-A1 1 dashboard trim 1501.23 1501.23 996-731-619-30 1 door mirror housing (L) 840.66 840.66 996-731-620-30 1 door mirror housing (R) 840.66 840.66 996-559-237-92 1 logo "GT3 RS" (BLUE) 11.53 11.53 996-559-331-91 1 decorative film front (L)(BLUE) 36 36 996-559-332-91 1 decorative film front (R)(BLUE) 36 36 996-559-333-91 1 decorative film lateral (L)(BLUE) 97.29 97.29 996-559-334-91 1 decorative film lateral (R)(BLUE) 97.29 97.29 996-559-335-91 1 decorative film rear (L)(BLUE) 59.79 59.79 996-559-336-91 1 decorative film rear (R)(BLUE) 59.79 59.79 996-580-982-02 1 rollcage 2385.04 2385.04 996-505-980-92-90 1 front bumper lining 1238.27 1238.27 996-511-011-91-G2 1 front hood 3971 3971 996-511-551-91 2 gas-filled strut 7.19 14.38 996-512-991-94-90 1 rear cover 3598.93 3598.93 996-512-959-94 1 rear spoiler 2280.13 2280.13 996-512-983-94 1 plate (L) 359.89 359.89 996-512-984-94 1 plate (R) 359.89 359.89 999-073-334-00 6 round head screw M6 x 16 6.04 36.24 996-803-033-91 1 seat belt (L)(BLUE) 111.69 111.69 996-803-034-91 1 seat belt (R)(BLUE) 111.69 111.69 32436.24
#40
Technical Guru
Originally Posted by Holger B
Doesn't it have different heads too?
#41
Originally Posted by JasonAndreas
It might be worthwhile if you DIY (i.e. free labor)
#42
Yes, a few messages prior I wrote, "Not including the cylinder heads or the donor GT3 the total for parts comes to $32436.24USD". The two cylinder heads are $1658.25USD/each but the labor charge for installation will easily cost as much if not more making their addition not really worthwhile for the minor performance improvement. It might be worthwhile if you DIY (i.e. free labor) but when you add up the cost of the required tools you're not really saving anything.
And I fully agree that it's not worth the price or effort.
#44
Technical Guru
Originally Posted by Red9
Jason- is that total list to convert? I am trying to get a clear picture on this.
