Need Part numbers for LWF/clutch and rsr pressure plate
Does ne one know the part numbers for the GT3 LWF/clutch and RSR pressure plate. Thanks. Mike
Good info from prior posts on this by JasonAndreas:
Here is the Porsche part number application list for 911 based pressure plates.
964-116-027-90 968 (green)
959-116-023-05 959
964-116-028-03 993 (no mark)
964-116-028-53 993TT & 964 3.6T (red) & GT3 mk2
964-116-028-91 964 3.3T
964-116-028-90 964RS & 964(blue)
996-116-027-51 996 GT3 mk1 & 996TT
996-116-027-02 996
996-116-027-05 996 (M96.03)
997-116-027-12 997 (M97.01)
997-116-027-00 997 (M96.05)
the RS has the same pressure plate as the regular GT3 (part #996-116-027-51)
what items do I really need to buy?
964-012-239-31 (1) Flywheel
964-114-143-31 (1) Starter ring gear
931-102-111-00 (1) ball bearing
928-102-151-01 (9) cheese head screw
996-116-015-30 (1) clutch disc
N-014-715-3 (9) cheese head screw M8 x 45
944-116-080-01 (1) release bearing
950-116-813-30 (1) guide tube
900-270-055-02 (2) Casket head screw M6 x 14
These numbers may/probably have been superceded but if you give them to a dealer the latest numbers will pop up on their computer screens.
959-116-023-05 959
996-116-027-02 996
mike i am about to pull trigger on tranny upgrades as the dealer has pulled the tranny..did you use these parts? pully? lsd? i am really lost as i just got the car and this opportunity of no labor tranny upgrades is upon me...please any more recent suggestions on what you would change or upgrade on the tranny...so far on searched, rs lwfw, rs pulley, cup pressure plates, lsd?
or maybe just track the car a year then start thinking about upgrades...hate to miss opportunity for tranny upgrade with no labor cost but don't want to waste $$ ..unfortunately no race shop near and porsche here does not do much track stuff...thanks
GT3 player par excellence
talk to GT transmission (sponsor here) and either get a full unit or have them rebuild the innards.
use RS lwfw and RS pressureplate. mike has RSR stuff, it's very stiff.
if you want more, get 4.0 ring and pinion
if you can't find a shop, have dealer pull the gear box, ship to brian copans (Athens, GA) and he will do the rest.
If they are opening the tranny how much u willing to spend? Rs lwf with rs pulley, cup pressure plate(sachs race engineering) with cup disc is the minimal u can do. If your lsd aint toast I would forgo changing it and besides if u add lsd later like a Guard unit - u dont need to remove tranny. You could change gear sets optimized for track or r/p- both are $$$$ but since it's a new car for u better to learn as is. Mike
thanks guys..ordered rs clutch lwfw and pp..i heard the stiffer clutches are really hard to drive 1st and 2nd gear on the street..stall outs etc,,,
talked with matt at Guard.. about a grand to make it upgraded similar to cup car lsd...
thanks mike, think if lsd is still good and dont have to pull tranny (i saw the diy) will hold off on lsd until get some track time....hate to miss a track day for the lsd![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
thanks
thanks
I have the 3.8 rsr pp with disc. It's definitely heavier as mooty stated. Track conditions u won't notice that much but streetcarwise- your leg can get cramped. My 6 is pretty much 99.9% track only to/fro track so no issues with pp. The thing with LSD on the street u cannot tell difference between open or if it's locking- only in the track- scary rear end waggle under hard braking and slow as a pig exiting out of corners(ability to rotate is compromised to). Neway have fun at the track and be safe. Mike
