Engine Question
Originally Posted by khaug
Is the GT3 engine a twin-plug or single-plug design? If twin, do both plugs fire simultaneously?
Thanks.
-Karl
Thanks.
-Karl
I don't know why they got rid of that - maybe it's not needed with the new 4-valve heads on the water-cooled motors. The compression ratio on the GT3 is certainly no slouch (higher than the twin-plug 993).
If Iremeber right the 993 fired at diffrent times not at the same time, as an attempt to reduce emmissions on the air cooled engine, Changing to water cooled engines that maintain a much more consitent teperature its much easier to control emissions and does not require dual plugs
All you have to do is look at the 2 heads side by side and you will immediately see why. With the 2 valve head, the spark plug is way over to one side of the combustion chamber, and it takes forever for the flame front to get across the cylinder. That's why they put the second spark plug on the opposite side, to cut that time in half. The 4 valve head has the spark plug directly in the center of the combustion chamber, and has the shortest distance to ignite the total mixture, in a uniformly radial pattern. Can't get any better than that.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
