FS: Brey-krause Aluminum Harness Truss For Porsche 996 GT2 & GT3
Slightly Used in Excellent condition.
http://www.bkauto.com/porsche/r1035.php
This harness mount was developed in response to customer requests for a truss-style harness mount for the Porsche 996 coupe. The new R-1035 features water-jet machined aluminum construction much like our R-1025 harness truss. Like all Brey-Krause harness mounts, the R-1035 uses only existing mounting points. No drilling, welding or fabrication is required for installation. Once installed, the main portion can be unbolted in ten minutes, allowing use of the rear seats.
The R-1035 been tested and certified by an independent lab to handle the types of forces required by the National Highway Traffic Safety Admin. DOT and SAE J385 Rev.MAR 95, Motor Vehicle Seat Belt Anchorages-Performance Requirements. This harness mount bar properly locates and supports racing shoulder harnesses relative to the driver. In the case of an accident, it helps protect the driver's shoulders and spine. The harness guides also prevent excessive shifting and fatigue of the driver during the high G loads of cornering and braking.
Retails for $1K
Also included is the GT2/GT3 Adapter bars $150 value
(Standard bars NOT included you can probably buy them from BK)
Construction:
6061 T-6 anodized aluminum skeleton
Type 304 stainless steel black powdercoated strut mount
Weight is 15.5 lbs
$700 - Shipped This thing is a work of Art!
The condition is excellent 9/10. I did not install this, but it seems very straight forward.
Retails for $1K
Construction:
Weight is 15.5 lbs
$550 shipped
This bar is setup for a GT2 or GT3 only comes with the upgraded hardware for the 2/3. In excellent condition. I am selling this at hald the price of new. If you don't have a Tequipment bar and want to run 5pt harnesses this is the way to go! It goes on ebay in the morning.
