996 GT2/GT3 Forum 1999-2005
GT3 engine problem
Old 04-21-2006 | 12:58 PM
Bill911's Avatar
Bill911
Default GT3 engine problem
Driving to work this morning I noticed my car was running rough at 3k rpm's and was hesitating a bit. After about 15 minutes it got really bad and I was losing power and the check engine light was flashing on and off. It felt as if the car was misfiring. I was able to get to my office. Right now the car is beiing towed to the dealer. Last night I installed new sport cats and did a road test and it was fine. Anyone have any thoughts of what the issue could be?
Old 04-21-2006 | 01:08 PM
viperbob's Avatar
viperbob
Former Vendor
First guesses are throttle position sensor or MAF.
Old 04-21-2006 | 01:13 PM
yetis's Avatar
yetis
It sounds like a problem I had on my C4. It turned out to be a bad coil pack. Took two dealers to figure that out!
Old 04-21-2006 | 01:26 PM
MJSpeed's Avatar
MJSpeed
The Rebel
I had an issue with mine, however it wasn't as prevelant as what you described...turned out the ECU needed re-mapping. According to the service guy the ECU "lost" it's programming...
Old 04-22-2006 | 03:47 PM
LA964RS's Avatar
LA964RS
Electrics....that's where you'll find the gremlin. Let us know what you hear after they hook up the hammer.
Old 04-22-2006 | 09:21 PM
NJ-GT's Avatar
NJ-GT
what kind of sport cats did you install?
Old 04-22-2006 | 10:42 PM
GT3 Chuck's Avatar
GT3 Chuck
NJ-GT is on the right track...quite possible your "sport" cats put the car in limp mode...too coincidental to be much else...good luck
Old 04-23-2006 | 08:50 AM
Bill911's Avatar
Bill911
The dealer called me late friday to say that three of the cylinders were misfiring but did not have anymore time to look at it. I will find out more on Monday. The sport cats in installed were from Fabspeed. I called them to see if it was coincidental that I had this issue right after the install and they said they have never heard of that happening.
Old 04-23-2006 | 01:35 PM
Jim H.'s Avatar
Jim H.
I had the exact same problem on my GT3. It turned out to be part of the variocam system that had one bank of cams off timing. I think the variocam adjuster was "hard over" one way. They replaced one hydraulic part and it's worked fine since. Good luck.
Quick Reply: GT3 engine problem
