Should I buy Ceramic Brakes ?
#31
Originally Posted by bora
I had both on my car and drove them back to back. I think the linear response you speak of has more to do with the pad compound than the rotor material IMHO.
R+C
#32
PAGID Friction Compounds
PAGID racing compounds are complex formulations with very high content of ceramic materials. All Pagid materials are asbestos free. The difference to competitor’s ‘metallic’ compounds is the superior thermal insulation and the higher heat resistance of ceramic compared to iron. Ceramic has, to the contrary of iron, very low heat conductivity. Consequently less disc (rotor) temperature goes through the pad into the caliper.
I agree with you guys that if you plan to track a car, PCCB does not make sense. It is a wear item, and it costs 10 times the price of iron, yet lasts only 2 times as long. You guys have convinced me!
But don't say ceramics are not superior in several ways. They are - there is too much engineering to say otherwsie. They just cost too much.
#34
Not sure anyone would argue that the ceramics are inferior on anything but cost.
I was pretty upset replacing mine with steels when I felt the weight difference!
#36
Originally Posted by Black Shadow
Can anyone tell me why the 2005 GT3 PCCB rotors have a different part # then the 2004 rotors???
#37
I spoke with someone who may know a whole lot about the subject of PCCB's on the track at PDE this week, and he said that the PCCB rotors won't wear or need resurfacing, just remember to keep a spare set of pads and replace them before you get close to wearing them all the way down and ruining the ceramic rotors. This was in response to my question about whether the order the PCCB's on the new GT3.
BTW, will the PCCB's on the forthcoming 997 GT3 have a newer generation rotor than previously provided on the 996 GT3's?
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
#38
The best, virtually only source of information about new generation PCCBs are the Supercup teams. They will tell you that whilst the PCCBs will last longer than iron rotors under ideal circumstances, they are still more expensive to run than the iron rotors.
Running PCCBs in the Supercup was part of PAG's campaign to make people want the damn things. It may or may not be a coincidence that at the same time that they put the PCCBs on the Cup cars, they removed the race ABS.
There are no reasons, apart from weight saving to use PCCBs over the very best iron rotors. The very best are more expensive than the stock PAG offerings, but way cheaper than the PCCBs.
R+C
#39
#40
lawdjc: I will go with DanH. My pads are changed at 50-60% wear and I am not on the first set of PCCB rotors. THEY WEAR. They last longer then irons however at a replacement cost of $5100 each do not last long enough (if tracked).
#41
If he is so sure, will he take 1000USD to warranty mine for track usage? He buys me a new set when they die (and they will!)
I do appreciate your help!
#42
it very much sounds as if your PDE expert has been reading from the Giant Weissach Book Of Comic Stories. Gullible, like Gollum is spelled with a capital G. Because he has bought into the myth, there is no need for the rest of us to fo,llow suit.
R+C
R+C
#43
To be fair the PR machine keeps rolling and every time I read a magazine they all seem to say how the ceramics are a 'must have if you intend to track your car'. Still, if they can get mugs to keep buying them, perhaps the cost will come down
#45
Originally Posted by roberga
The GEN II is light years better then the GEN I. It is obvious that Porsche made a mistake with GEN I as well as the folks that purchased a car with them.
If I approach it from a different angle, suppose I track the 997 GT3 a half dozen times a year. Will Porsche cover the PCCB rotors if there is a problem, or will it say "too bad - nothing is covered once you are on the track." After all, the new GT3, as well as the previous GT3, are marketed specifically to be used on the track as well as on the street.
Any thoughts on this?
