996 GT2/GT3 Forum 1999-2005
Battery Relocation Complete - pics
Old Feb 9, 2006 | 09:52 AM
grussell's Avatar
grussell
Default Battery Relocation Complete - pics
I finished the battery install last night. here are a few pics. The new battery weighs 22lbs, so I should be down to 3,125lbs.
Old Feb 9, 2006 | 09:53 AM
grussell's Avatar
grussell
another view
Old Feb 9, 2006 | 09:54 AM
grussell's Avatar
grussell
one more.......
Old Feb 9, 2006 | 10:21 AM
Mr. C4's Avatar
Mr. C4
Very neat! What hardware hav you used? Have you thought about the battery getting crushed in case of a heavy front impact?
Ciao,
Old Feb 9, 2006 | 10:39 AM
grussell's Avatar
grussell
Ciao,
Mr. C4,
I used the battery tray from west coast batteries and 4 vibration isolators to secure the battery. It was a clean, easy install. I am hoping not to have a heavy front impact.
Old Feb 9, 2006 | 10:44 AM
Mr. C4's Avatar
Mr. C4
grussell,
Any website to West Coast Batteries?
Ciao,
Old Feb 9, 2006 | 12:08 PM
viperbob's Avatar
viperbob
Former Vendor
http://www.odysseybatteries.com/
Old Feb 9, 2006 | 05:09 PM
RayGT3's Avatar
RayGT3
GRussel,
Thanks for stepping up with these pics. It's much appreciated.
Summit racing has the mounting bracket at a reasonable price as well. Also check Electro Battery in NJ, for batteries, pretty good pricing. (Usual disclamers)
Ray
Old Feb 9, 2006 | 05:21 PM
RayGT3's Avatar
RayGT3
GRussel,
A few questions, if you'd be so kind. What was the length of the positive cable used and do you think that was an optimal length? Where did you terminate the negative cable? Did you use the 4 gauge or go to the 2 gauge wire? TIA
Ray
Old Feb 9, 2006 | 05:50 PM
grussell's Avatar
grussell
Originally Posted by RayGT3
GRussel,
Ray
The positive cable is about 60" and I terminated it to length
If you look at the first pic closely you can see it is grounded just a few inches away from the battery.
I used 4 gauge cables
Old Feb 9, 2006 | 09:17 PM
FixedWing's Avatar
FixedWing
Probably isn't needed in your case as the cabling is relatively short and all contained in the front compartment but in my own case, when I relocate the battery I will add a 100 amp fuse just in case there is a short somewhere. One of the advantages of the AGM battery is that there is no limit to the discharge rate.
Also, presumably, you did this for weight & balance reasons, so why didn't you move the battery even further forward (and to the right)?
Stephen
Old Feb 9, 2006 | 10:30 PM
0396's Avatar
0396
'Also, presumably, you did this for weight & balance reasons, so why didn't you move the battery even further forward (and to the right)?'
My same thoughts...
Old Feb 10, 2006 | 12:18 AM
grussell's Avatar
grussell
My same thoughts...
I don't know!
Old Feb 10, 2006 | 12:28 AM
RayGT3's Avatar
RayGT3
FixedWing,
When you say "to the right" are we talking driver side or passenger side? What might the reason be for putting the weight to one side?
I think the cup cars have the battery placed in the center as well, could be wrong, but I thought I remember seeing it mounted centered. Not to say that is correct, just making a comment.
Old Feb 10, 2006 | 02:21 AM
FixedWing's Avatar
FixedWing
FixedWing,
When I say to the right I mean to the passenger side in a LHD car. I don't know for sure but I am guessing that with the driver alone in the car, there will be an imbalance to the left (driver) side. Placing the battery as far to the right as possible would counter that -- just as placing it as far forward as possible will counter the rear weight bias of the car.
As to the Cup car, maybe they use other methods to balance out the weight of the car?
Another small advantage I can see to putting the battery on the right is that the positive cable can be slightly shorter as currently routed. And if you ever did want to store something else in that space (not sure if that would be a good idea without better positive protection) then having the battery in a corner of the compartment would make for more useable remaining space.
Stephen
