Vid - GT3 Road Challenge
Found this very nice GT3 joining rallys. It was already discussed a few month ago. Found now a second vid about it.
Here's a little preview:
and here is the vid:
http://www.porschegt3roadchallenge.c...den/Movie1.mp4
and another vid from the Ardenne Bleue Ralley 2005, the GT3 in action, the sound is absolutely great. i guess this one was already posted in another topic. but i list it here to complete my post:
http://www.embedded-speedstyle.de/me...e05/deuzHQ.wmv
Technical Data Porsche 911 GT3 Rally
Body
Weight-optimised 911 GT3 body
Carbon-Kevlar parts: trunk lid, wings
Plastic rear window and rear side windows
Underfloor preservation CRP
Racing seats with six-point seat belts
Fire warnings and extinguishing system
Welded roll cage
Tank: 64 litre
Adjustable rear spoiler
Spare wheel in interior
Engine
Water-cooled 6-cylinder Boxer engine motor in the rear, 4 valves per cylinder
Cubic capacity: 3,598 cm, stroke: 76.4 mm, bore: 99.99 mm
Max. output: approx. 381 HP (280 kW) at 7,400 rpm
Max. torque: 380 Nm at 5,000 rpm
Max. engine speed: 8,200 rpm
Titanium conrod
Dry sump oil system with oil-water heat exchanger
Sequential fuel injection (Bosch)
Motor electronics Bosch ME 7.8 with anti-knock control
Fuel: Super Plus unleaded, 98 Oct
Power transmission
Synchronised six-speed transmission
Rear-wheel drive
Racing clutch
Locking differential: 40/60%
Oil-water heat exchanger for transmission cooling
Top speed: 247 km/h geared up (6th gear at 8.000 rpm)
Suspension
Mc-Pherson front suspension
Multi-link rear suspension
At front and back adjustable transverse stabilisers
Coil springs all round
Sachs gas-pressure shock absorbers, pressure/traction adjustable
Height, camber, track finely variable
Alloy rims
Power-assisted steering
Tires
Front axle: 8.5J x 18 ET40 on Michelin 225/40-18
Rear axle: 11J x 18 ET63 on Michelin 295/30-18
Brakes
Brake force distribution with adjustable brake compensation
Front-axle brake disk: D = 380 mm, 34 mm thick, 6-piston aluminium fixed calliper
Rear-axle brake disk: D = 355 mm, 28 mm thick, 4-piston aluminium fixed calliper
Body
Welded roll cage
Tank: 64 litre
Engine
Titanium conrod
Power transmission
Rear-wheel drive
Racing clutch
Suspension
Alloy rims
Tires
Brakes
