Studs on New wheels
Studs on New wheels
I just got my new wheels today. Fikse Profile 5S all back and a set of Studs for them.
Question Can I use the standar lugs for them.
Or shoudl I just go ahead and Studal the wheels
Pics will come tomorrow
I guess the are screw in about 2 1/2 in of thread then solid no thread and then after the solid part there are a solid stripes that are about 1 cm long.
I will take pics and post them tomorrow ( Hope my explanation makes sence
Those are different than the studs I used... my studs are screwed in from the outside...as you would your wheel bolts...they do no have a head on them... they have a small threaded area which screws into the hub.. after that they are the same as yours above.
To install those in the picture you will have to do some work.. the screw in studs that i have used are easy to install... just screw them in with a allen type head bolt.
I needed the wheels studs to fit the larger BBS Motorsports wheels with a spacer..
why do you need them?
dont realy know the fikse wheels I got are same off sets but diferent size, 18x9 and 18x12
same size on front and 315 in the rear, they send me the studs so i could change tires faster for track days
You do not need them.. some use them to ease wheel changes.. I believe there is a bit of work to install them....pressed in wheel studs.
My BBS wheels need a longer bolt. they are thicker threw the body... no choice but wheel studs for me.
