How much difference does it make.......
I drove another 3 that has the RS wing, and it felt MUCH more planted thru the turns than my car with the 8 degree shims. I already have the right alignment and both cars were set up by the same person so it must be the wing. Not an inexpensive item, but it seems to really make a big differnce. I also hear that it has lease drg too.Before I commit to it, any thoughts, opinions, observations, insight, wisdom. etc. Thx.
I've only driven mine at Laguna (not a super fast track) with no shims and it didn't seem to make a difference to me.
Since then I've put in the 4 degree shims but I haven't driven it yet at the track.
-Kevin
-Kevin
Richard,
Get the RS front bumper as well -- they were designed to work together. John's car has both. It was a great seeing you at the track yesterday.
Originally Posted by Jack
Richard,
Get the RS front bumper as well -- they were designed to work together. John's car has both. It was a great seeing you at the track yesterday.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
-Kevin
![](http://images14.fotki.com/v209/photos/7/70977/766839/IMG_1330-vi.jpg)
GT3 player par excellence
4 kurves. your RS nose... do you have to paint it or does the white actually match. the one i saw at devek doesn't match my cararra white.
hum... the devek one must be an anamoly then. it looked "off" to me. well, maybe my whole car was defective, LOL.
Originally Posted by CodeRed
Kevin,
What is the "motorsport lip"? Sounds like you should have to go to a massage parlor for that part![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I have been using the RS wing with 4 degree shim and Cup front splitter. Definitely is a big improvement at speed compared to stock wing. The car feels more planted and is less unsettled when braking or lifting at high speed. Confidence inspiring.
I'll second that emotion. RS wing with Cup car splitter is the ticket. I've used them at Fontana at over 160 and it was very stable. I also have the RS intake grills that add downforce to the front and balance out the wing.
You don't need the RS bumper (although it looks pretty). If you do use it, then you should take advantage of the extra cooling holes by upgrading the radiator, otherwise it is just cosmetic. I might do this, but I will put the cup car radiator upgrade on it if I do. So far, no cooling issues whatsoever.
That RS nose looks like an exact match on 4Kurve's car!
Kurve's would it be alright with you if you shared your VIN with me? I'd like to check out the paint coding. This is very interesting.
Thanks,
Austin
Thanks,
Austin
Code Red,
you shouldn't run any extra splitter, 4 deg or 8 deg, WITHOUT the front splitter.
All you are doing with the shims is putting more downforce on the rear, thus making the front lighter, so I'm not surprised that your car feels loose.
