Weight of Dual Mass vs. Single Mass Flywheel Components
Here are some weights I though might be of interest regarding the Dual Mass Flywheel (DMF) versus the Single Mass Flywheel (SMF) components for a GT3 weighed by me on my balance beam scale:
DMF= 30 pounds (includes integral starter gear)
SMF= 11.8 pounds
SMF Separate Starter Gear= 1.3 pounds
Total SMF equivalent to DMF assembly= 13.1 pounds
DMF Driven Disc (Un-sprung) =2.8 pounds
SMF Driven Disc (Sprung) = 4.3 pounds
Net saving= 15.4 pounds or exactly 7 Kg, what Porsche says it saves for the 964 RS, the first car that used the SMF parts.
I hope this is not a repeat of what others have posted.
SMF= 11.8 pounds
So is it possible to put any meaning to this figure? How much difference should 7 kg on the flywheel make?
Stephen
Originally Posted by Z06
The engine will use less HP to turn the drive train.. quicker acceleration.
Stephen
lightened flywheels do indeed make a difference. They are one of the cheats used by race teams when they need to win in front of the sponsors. They get caught but the sponsor goes home happy.
I have seen beautifully made steel and aluminium flywheels. These are prone to problems as the torque causes the steeel screws to create wear in the aluminium main body, be warned. The better German manufacturers are able to produce all steel lightweight flywheels.
The McLaren F1 has no flywheel, how's that for a weight saving?
R+C
R+C
Originally Posted by DanH
Does make the car sound like a diesel at idle though! At least my GT3 RS clatters away like one sometimes!
Originally Posted by arenared
Pardon my ignorance as it is not obvious to me, but what SMF and clutch did you use? Is it a specifically lightweight aluminum one?
