Specs for stock GT3 alignment
Have searched the archives and found several track recommended specifications for GT3 alignment but not the factory recommendations. Does anyone have them and could post. TIA
Howard
Howard
Official Alignment Specs GT3
2004 GT3
Front axle height: 115 + 5mm (115 to 120mm)
Rear axle height: 128 + 5mm (128 to 133mm)
Front axle:
Toe unpressed (total): +8' ± 2'
Toe difference at 20° lock: -1°30' ± 30'
Camber: -1° ± 5'
Max camber difference, left/right: 10'
Caster: 8° ± 30'
Max caster difference, left/right: 40'
Rear axle:
Toe per wheel: +13' ± 2'
Max toe difference, left/right: 5'
Camber: -1°50' ± 5'
2004 GT3 RS
Front axle height: 113 + 5mm (113 to 118mm)
Front axle:
Toe unpressed (total): +2' ± 2'
Camber: -50' ± 5'
Caster: 8° ± 30'
Rear axle:
Camber: -1°50' ± 5'
formula to convert to total toe in inches is 2 * 18 * sin(a) where the 18 is the wheel diameter and a is the
angle per side
2004 GT3
Front axle:
Camber: -1° ± 5'
Caster: 8° ± 30'
Rear axle:
Camber: -1°50' ± 5'
2004 GT3 RS
Front axle:
Camber: -50' ± 5'
Caster: 8° ± 30'
Rear axle:
Camber: -1°50' ± 5'
angle per side
