Rear Spoiler
Do I need to change the setting/angle of the rear spoiler for track events? Is it easily adjustable? I noticed a small cover piece near the underside of the wing.
I know the Cup cars have lots of adjustment holes, and I heard of 4 or 8 degree shims for the Street GT3.
Do I need to get something like this or is the car stable enough with the standard setting?
indeed, just pop out the little tabs on each wing pillar and loosen the screw.
theoretically, you don't really need the shims, but they are good for making sure both sides are the same angle.
for street use, best not to mess with the angle.
It is recommended by some club racers to set the wing at 10º+ or so. Just carefully pry the plugs under the wing off and use a #40 Torx head socket. The OEM bracket is substantial enough to not need the shims for a day DE. I liked the way the car felt on higher speed turns. Play with it! Another fun part if the car to enjoy.
I do WGI, VIR, Mosport and Mt Tremblant most often.
Are there adjustment holes, or is it a continuous slot that must be alingned on each side? I've looked though my Owners Manual and can't find any info!
I just didn't know how critical the angle is. (I'm watching F1, and I know it's not as critical as it is for them!)
"It is recommended by some club racers to set the wing at 10º+ or so. Just carefully pry the plugs under the wing off and use a #40 Torx head socket. The OEM bracket is substantial enough to not need the shims for a day DE. I liked the way the car felt on higher speed turns. Play with it! Another fun part if the car to enjoy."
Can you say holy understeer? Some friendly advice - With no other adjustments to the front to balance the wing increase, you will burn up your back tires. Take advice from a professional or someone who knows what they are doing!
I've got the RS wing & the 4 degree shims. The car is more planted in fast turns and you give up some speed down the long straights. I'm happy with the setup so far, but I'm not the fastest guy out there...
Holger like vegas said need something upfront too to offset downforce on back esp with that nice wing of yours : ). I never felt back getting loose its the front part I'm feeling. Wish lip could be lower(I have cup lip) but then again for a daily driver won't work unless swap back and forth. Is there a bigger /lower lip spoiler with respect to the cup one? Regards. Mike
IIRC - There was an article in Excellence that had an engineer talking about the GT3 aero and suspension. He said that if you increase the downforce on the back then the equivalent change was to lower the front ride height to increase rake. He did caution that any changes to the rear should be offset by an equivalent change to the front and this should be done by someone familiar with the "airframe". I think it was the article entitled "Track Daddy" and it was about 1.5 - 2 years years ago.
Basic Site Sponsor
Basic Site Sponsor
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
vegasgolf, thanks, understeer is what I was concerned with also but I did not feel any even on the higher speed turns (what little there is at Putnam Park). My car has the Roland Kussumal alignment with the front ride height set to 115 mm. That may have made the difference. The car was a little looser without the wing angled than my low skill level was comfortable with, especially in the faster corners. There is no doubt with the OEM alignment it would have understeered horribly. The OEM alignment pushed exiting the turns and was wearing the outside edges of the tires both front and rear. Now the tires (MPS2) are looking good, very even wear with 4 DE days so far.
I agree with Larry....on the fast corners it's the back end I feel that need's more grip as I get on the throttle ...on the slower corners maybe I am braver but it understeers on corner entry....
it's seems to do different things at different speeds...corner entry ...mid corner and corner exit all seem to change.
Larry,
Why do you not run your wing at 8 deg? Do you think there is a gain with the RS wing over the stock piece.
Larry,
Basic Site Sponsor
Basic Site Sponsor
Larry,
Larry,
