PIR ORPCA DA Yesterday
We had 4 GT3s and the track was configured without the chicane on the front straight so speeds were extremely high, over 150mph. How much over depended on the size of your huevos, as threshold braking from over 150 on a green track in an unfamiliar configuration was interesting. We usually run the chicane, in the CART configuration. Of my 4 run sessions, 3 were dry and one was wet. The dunlops worked extremely well in the wet and in the dry; many of the guys running cups sat out the wet run. I am just amazed how capable these cars are on a racetrack. The turbos didn't have a chance. I wish the guy I spoke with who recently bought a 997s had showed up as he told me he bought the s over a GT3 because he wanted the faster car.
robyn,
Is he a moron or maybe he ment the Z3. It seems to never end. Maybe the 997 is faster in reverse??
It must have been fun. I have only been on that track with the chicane. Will you be there for the Rose Cup? It would be fun to have a pack from Seattle heading South on that Friday :-)
No, he meant GT3. I told him I'd rather drive in his car to Bandon Dunes but on the track? Come on. Porsche is not going to race a 997S.
This is Chris, we met earlier this spring. I've also got a Guards but I've got 1 piece Champions, tech bar, GT seats, 6 pt harnesses. Of my 15 or so times on PIR, this is the first time I've run the course without the chicane. It was wild shifting into 5th and keeping it pinned as the speedo ticks through 150.
I'll be going frequently and hope to run with you soon. I'll make the Rose Cups if I can. There is nothing as much as fun as getting a pack of 3's running together harassing (one word Senator Packwood) the turbos, the vettes, etc.
Any pics?
No pics Holger, too busy drivin' and instructin'. Street, Derek did very well. He can't wait to go again. The WRX is a good car for him to learn in as it is very forgiving. My dunlops worked very well in the rain. You going to BMW day this Thursday? I might be able to squeeze it in.
I just picked up my gt3 a couple of weeks ago and would be interested to hear how many (if any) of you have adjusted the rear wing? I'm curious to find out if it helps keep the back end planted under high speed braking situations? Coming down the back straight at Mid-Ohio (145mph+) and under hard braking was the only time i got uncomfortable in the car as rear got light it really started dancing around on me...
Oh ya, the new car... carrera white/black. big reds. I still pinch myself everytime i get in it!
The guy who sets up my car(Greg Fordahl engineer Alex Jobs) had me put 8 degree more wing on my car. It does help at least for our track. I would suggest finding somone that knows your track, maybe something less would work better for you.
Originally Posted by Shrews
I assume you had to buy shims to achieve 8 degrees? Also, what is the best way to pop the covers off and gain access to the rear wing bolts?
shrews
shrews
There were some threads on this. They're not easy to remove without damaging them. I put some scotch tape on the end of a screwdriver and pried them off. Seems to work well, but one side has a little cracking. You'll need a Torx T-40 to loosen the bolts that hold the blade on.
I spray painted my shims flat black. Easy to do and looks really good.
For you guys who have increased the AOA of your wing in search of more downforce, Have you made any alterations in front ride height to create more front downforce as well?
I remember reading a comment from a Porsche engineer who stated that increasing the wing AOA required a lowering of the front of the car to maintain balance at speed.
Comments?
Thanks.
Comments?
Thanks.
