New Owner -- Got a few ?'s for the guru's
Yeah, I am not sure what Andrew put on there.....he did mention that because of the brake ducts, it will rub on full (close to it) lock. Maybe he installed the cup car ducts? I guess I will have to rack it and take a look. Thanks, Tim
Originally Posted by Larry Herman
When I have the muffler bypass pipes on, there are no other noises.
On that note, I would like to hear some exhausts in person. I had a B&B on my M3 (with a track pipe too). That is about the loudest combo you can get, and I liked it a lot.
But I want to hear some GT3's with different exhausts.....maybe I will post and see if there are any around Sacramento. Will less than 1000 GT3's in the US, it may be hard to find one! Tim
I think I may know what noise you are talking about.
Does it only occur when the engine speed comes down to idle?
I have a "chirpping sound" - you have to listen real careful for it - but it sounds like a chirpping sound when the engie comes down from any rpm and settles into idle. Usually i hear it just as the needle comes down to 1000 or 1200rpm.
I mentioned it to my mechanic and he had a similar sound in a 996 Turbo and it ended up being a problem with the power steering system.
Yes, that sounds like it....on my next service I will have them take a look at the power steering. Thanks, Tim
just drive down to San Francisco
between Napa and Sunnyvale, you will find a dozen different GT3s, and some with M3s too...
I noticed something "new" about that sound. It is only when turning a bit.....like it is diff related. My buddies car did it too, but not quite as loud. It only happens at low speed, low rpm, when turning the wheel....such as coming out of a driveway...and then taking off, again, while turning. Must just be the LS diff noises. Tim
Easiest thing to do is to hook up with some other GT3 owners in your area and have them get in your GT3 (vice a versa) and listen. Rennlist and PCA are great ways to get connected with other owners.
Still plays with cars.
Tim - you made me curious and I checked ouot my car (preppiing it for a track event next monday-thursday and yes, it makes a funny noise when driving in first or reverse right after startup. I've gotten so used to it that I ignore it. It does sound something like a fast coffee percolator. Wife's GT3 also does it. Part of the charm.
A' HA!! So I am not crazy. LOL. I think the sound may be related to the limited slip???? My car does it all the time....hot or sold, but only when going slow....Tim
