Toyos RA-1 275/35R18 and 335/30R18 on stock GT3 wheels
Proven tire on the SpeedGT races, on rainy days, cold days, etc.
They last longer than MPSC. I don't have to quit a track session because of heavy rain anymore. Good grip when cold. Not bad for autocross either. In my opinion the perfect street/track/autocross tire.
I'm running the stock ride height rear, and -17mm from stock front. I didn't roll the fenders. Car is running -1.3 degrees camber at the rear on those pictures.
Cool pictures... how did the rear camber work out or better yet how was the ballance?
Do you think that the times you run with the Toyos could be close to the smaller size V710?
By looking at those pictures turn in is good
The smaller size V710 combo (245/285) is at least 1 second faster that this RA-1 combo on a 60 seconds race track. The V710 grip is unreal.
In fact, the MPSC has better grip when hot than these Toyos.
The car needs more negative camber at the rear: Something like -2.0. I'm running -3.0 front with the Manthey Racing camber plates.
Basic Site Sponsor
Basic Site Sponsor
We have to meet up sometime. Too bad you couldn't make the dyno day. I have to see your car with those Toyos on it. Maybe I can make one of your autocrosses this summer.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
If you are running the RA1's at full tread you still have a lot of speed left in them once they wear down a bit. Once they do wear down they are not rain tires, they are just as slick as other R compounds. The Speed Challenge guys run them shaved.
Are you running PCCBs now? I got a set of MPSCs (315,265) and the HRE Competitions sitting in the garage. I just can't believe thet will fit. The tires are so much wider compared the stock .. they are more like 335s.
Originally Posted by Z06
quartermile,
I am in the market for wheels..... could you post some pictures of your HRE Competition wheels and tires?
quartermile,
That's a nice looking wheel....I think that is the wheel i will go with....are they painted or powder coated?
Please let us know how they fit. Thanks for posting the pictures.
quarter mile -
you will not be able to run the 315s on 11.5s without rolling your fenders or enjoying rubbing. they will rub unless you run the highest rear suspension setting and you are using 11" rims. running the highest suspension setting in the rear partially negates the benefit of increased rubber in the rear, ie, takes away from planting the rear and getting more absolute grip. adding 1/2" of rim width will exacerbate the problem. this is one reason cup cars only run 11" rims in rear
i just installed 315 mspcs in the rear with 11" fiskes and rolled the fenders for proper clearance to give full adjustability in suspension (height, camber and toe)
Z06, I seem to recall the guys at HRE saying it was painted. The quality on this is far better than the Porsche wheels if that means anything.
Healyg, I took my car to HRE for a custom fit, they are right here in San Diego. One of their engineers took measurements and was pondering a 12" with 335's. Eventually we settled on the 11.5" rear with 9" front, offset inward by 1/4". So obviously I don't play with cup car rules so if this works it may be a GT3 first
