Corner balance with a half tank?
Keeper of the Truth
Originally Posted by 993_996_enthusiast
In what you posted from the manual I see the instructions for 'lateral' weight balancing but not 'longtitudinal' front to rear (other than advising one to keep the front to rear ride height difference within specs). So, I stand corrected in that they are doing a partial corner balance.
The GT3 Cup manual states, "Car to be measured with 1/2 Tank of fuel and 75 kg in the drivers seat. Joint and wheel bearing play checked (wheel bearing play can not be adjusted). Front and rear tyre pressure set to 2,0 bar."
