Floating hats
What are the right pads to use? I have a 25/75 street/track bias. I have heard the R19s mentioned. I don't want then to squel every single time I come to a stop, but a little noise wouldn't be that bad. The trade off is also rotor life I understand.
I am running pagid orange on my daily driver. Unless you are in stop and go traffic or a lot of slow stops of 20mph or below you shouldn't hear any squeeling. However I was stuck in bumper to bumper traffic - very rare for me, and I had to roll up the windows because the squeel was that loud.
Originally Posted by Jack
They make them for the rears as well, but you'll have to lose the parking brake.
not the case if i order them in quantity. Brembo can custom make those for us. question is will there be enough people that buy them.
Originally Posted by 20C4S
jack,
Great -- I just know what's on the shelf right now at RT/Brembo and available for immediate delivery/installation.
A -- you didn't call me.
Guys ive got floatings on my fronts but someone told me if I wanted them on the rear i will loose the handbrake. is that the same with you guys and also can anyone explain why it doesnt work?
i said i would & i did. shop hr just a little different than others. we don't get to leave til late most of the time.
Basic Site Sponsor
Basic Site Sponsor
20C4S - Myself and another GT3 tracker here would each buy a set of the front and rears (for a steel rotor car) if they will make them for the hand brake. I am getting only 12 track days on a set of front rotors right now. The rotors are cracking before the pads wear out.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I use the RS-19's on the front with the AP floating hats. I use the standard OEM pad and OEM rear brakes.
This is a fantastic compromise because I get cold street stopping power (and get to use my handbrake) and almost no squeaks as well as fantastic track stopping power. You don't need the rear floating hats, because the rear rotors are not subject to as much heat. Once, you've made the investment in the "hat" the rotors are cheaper than OEM "cup or stock". It is truly a win-win scenario with NO downside.
Pagid 4-2-1 compound for street, Pagid RS19 or 29 on the track (4-2 compound) on all fours. I do not recommend mixing compounds, the results are risky at best. As I've said before, the trick is to match the pads to the operating tempature of the rotors. Too hot is not good for some pads and too cold is not good for others.
"As I've said before, the trick is to match the pads to the operating temperature of the rotors. Too hot is not good for some pads and too cold is not good for others."
Exactly!
The rears are not getting as hot, so you can use the OEM which is fine for street and well as track use (I'm not talking about a 4.5 endurance race, but 30 minutes of track use at a time) If you dont' need to use track rotors (hats) that means they are NOT generating too much heat. You know this because the rotors are NOT cracking! Therefore the fine OEM pads will work for the rears. I have about 1,000 track miles with great results. The fronts need a high temp pad no doubt. Whatever your flavor is.
Exactly!
