Engine Oil Leak
Originally Posted by JMcD
Spoke to Joel Reiser, PCA Tech, and he said there have been a few RMS failures on German 964 cases , but very early in life, with little or no owner miles on the car. Porsche "swapped out at no charge". I cleaned the underside and saw nothing wrong. If it is a RMS, it's very slow or small at this time. I'll wait and have a dealer inspection soon.
Mine had the leak from new, just a very few drops in months from the same location. Build
date was 5/04. Why the heck can't Porsche straighten a problem like this out in almost
1 year?
1 year?
I had the same problem 3 days after I took delivery of my car. Turns out it was not the Main Seal it was a seal in one of the return houses of the dry sup system.. Have them check that . ( Hose goes right laong the sway bar.
by the way: the tech in the shop showed me the intakes.... smooth and shiny like would would not believe. That and gigantic vavles. Motor is back together and sounded great.
Glad to join the leak club fella's. I truly feel indoctrinated with Porsche finally. Good info here. Tomorrow I will get underneath and try to pin pt. the leak . I uderstand that the crank pulley seal can also be a culprit when leaking in this area...dead center on the sway bar......
