Question for people running Moton CS?
Where did you place the front and rear remote canisters?
Are you using the stock bump stops?
Are you using the stock spring perches?
GT3 player par excellence
_________
open the hood and look toward the rear of the car while you stand at the nose of the car. stare at the batter box, immediately to its left and right you can remove that two plastic trim pieces. under the trim pieces you will find a samll diagonal bar (don't know what the bar is for). that's where my front canister is attached. the rear canister is rounted inside of cabin and mounted on my RS clubsport roll bar.
___________
yes.
___________
yes for the front.
monoball from TRG for the rear. the rear shock mount is not true monoball (that's why my mehcanic told me) and when my CS was used with the stock rear mount, there's a lot of squeaking noises. yes, we lubricated just about everything you can and adjusted whatever is there to adjust. then we switched to true monoball and the squeak disappeared.
hope that helps.
_________
___________
yes.
___________
yes for the front.
hope that helps.
Thanks a lot.
That front bar is actually a strut bar. Perfect place for the fronts. I still need to figure out the rears. I was thinking on installing them attached to the rear cross link on the suspension.
I'm getting rid off the rear strut mount as well. Aluminum Monoball from TRG is a good choice.
