Clear Bra and CW color and AB delete
What is your opinion on a Clear Bra for a Carrara White GT3? For some reason I thought it wasn't a good idea and cast a yellowish hue, but I can't find that information now and it appears some on this board have it installed on their CW cars. Thoughts? Anyone with a recommendation for an installer in the Dayton/Cincinnati area?
Also, I'm interested in changing out my steering wheel for a non-airbag Suede Cup Car steering wheel. Has anyone done this and can it be done without causing other airbag issues (warning lights, no side airbags, etc.)?
Thanks much.
Thanks much.
Thanks much.
Thanks much.
This is my fourth car with the same film installed on it.
Overall in certain light, the film does have a slight yellowish hue, however
in most light you can not tell it is there.
The worst thing is that the white shows every little spec in the film so if you look at it from 5 inches, you see some dots etc. From 2 ft. no problem.
I think clear film looks great on red and dark silver cars. White is tough and from what I seen on black and very dark blue cars, that is a tough color also.
OTOH, the protection is real and well worth it. So I would say go for it.
GT3 player par excellence
i have the same film and same installer as bora, my too has slight yellow tint depending on lighting conditions. it's really not too bad.
Thanks. I figured as much but it does seem the protection is worth it. Now the hard part of finding someone near Dayton Ohio to install it.
Anybody with ideas on losing the steering wheel in favor of one without an airbag?
