Brembo floating hardware info
#46
Originally Posted by healeyg
the winning GT3 cup car at 24hr daytona had slotted ap rotors, required for the tougher conditions
#47
MDS,
I just installed the same brake system as you have. I am getting a clicking or clunking noise when I brake at a slow speed. I have checked everything and all seems well. I was wondering if you are experiencing the same noise? I am thinking that it might be due to the floating aspect of this set up.
I would welcome comments from others who might know as well.
#48
Originally Posted by Apex Late
MDS,
#49
MDS,
Thanks for the reply. I was going a little crazy. I had my guys chcek the bolts and even after they were tightened the noise was still there. The reason I was concerned is that the noise was not there for the first 80 kms or so until I gave the car a couple of good hard brakes. I am happy to hear that Brembo says that it is good to go. Although the noise is a little disruptive the brake capability seems much improved.
Thanks again for the prompt reply. Please let me know if you hear anything that is a concern with this.
Apex Late
Apex Late
#50
Keith, regarding tightening the bolts, torque them to 61 in-lbs. The nuts have a special oblong self locking shape, they should be replaced when replacing the discs. Also check the T-bobbins, replace if the coating is worn.
