Looking for help finding a cup wing
if you're going for a look thats one thing, but if not, you might want to try the 8deg shims on the existing gt3 wing for an effective compromise.
one nice thing about the stock gt3 wing is that is actually produces downforce through reverse lift, not just redirecting the air (ie, if you look closely, you will notice it is shaped like an upside-down airplane wing). the RS nor the cup car rear wings use that principle, ie, they sacrifice aerodynamics and top end for max downforce. the gt3 wing generates some downforce while maintaining good aero and top end
Pocket Sand
I wanted my car to be a little different.I put on a Cup car rear spoiler,a GT3RS front end and 3 piece BBS magnesium alloys.
It now looks like a Cup car which is what I intended.
Shane
Shane
Ciao!
I'm Franz From Italia.
Compliment for your "Street cup"!
Please a little question about the "BBS magnesium"; i know that they are not for street use,it's right? Or it's possible without problem use this type of wheels on the road?This type of alloy is only for a track use or it's possible use it always?
I love this type of alloys and i want it for my GT3 MK2 but i do not know wy in Italy and Germany is not Possible the use on the legal street (beacuse are not omologated,in Germany are not "TUV")
Thank you!
Franz
This is my GT3:
Thank you!
Franz
This is my GT3:
![](http://img86.exs.cx/img86/4763/conalaportieraaperta.jpg)
Still plays with cars.
Bruceg - I agree. As I recall, I was in a stock GT3 with Corsa's and you were in a Cup car with slicks. Indeed I gave you a signal and figured that you'd blow by in a flash - so I didn't lift. I was surprised that notwithstanding the faster exit from 8 that you couldn't pass. We (I did have another guy in the car) laughed and finally lifted to let you make T-10 without risk. So ... the obvious conclusion is that a Cup car has amazing cornering but all that downforce comes at the expense of drag. FWIW on my GT2 setting the wing for max downforce (8 deg.) reduced my top speed by 12 MPH on the back straight in spite of having way more power than a Cup car
Rgds,
Rgds,
Hi Franz
I believe there are various threads about this.I believe that you have to keep an eye on them as the centres have been known to crack.
I unfortunately cannot use mine on the track very much as Northern Ireland does not have many circuits.
Porsche have put Mag rims on cars before and the Race team I got them off said there shouldn't be a problem as long as you dont hit too many potholes or bang the kerbs on trackdays.
At the moment I have my originals on as the BBS have Pirelli Corsa tyres on them,better in the Summer
Shane
Shane
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
The carbon fiber RS wing is indeed wider than the stock wing; there is approximately 18" more width (left to right). The sides stick out past the air spoils from over the roof and fenders. Depth (front to back) remains about the same, but is consistent across the entire wing surface.
Additionally, the carbon fiber RS wing has a smoother and thinner front edge and more angle (front to back) than the almost flat stock wing. It features side winglets molded for downforce and for lateral stabilty.
I have yet to see wind tunnel documentation, but am confident in claiming increased downforce at speeds 80mph and greater even with the wing positioned at it's most flat setting.
The supports on the wing are angled for adjustability, made of aluminum, and support the wing well. It fits perfectly on the GT3 stock decklid uprights and installs and adjusts in minutes. It's a good product and pretty amazing that it weighs almost the exact same as the factory unit, yet does much more, with no need for a Gurney lip or big shims. The RS wing + cup car front splitter will provide more downforce.
The RS carbon fiber weaves we've seen thus far are consistently straight across all surfaces of the RS wing, it's impressive quality, not just contact paper over the fiber.
I'll try to find some time and take a pic of both wings (stock and RS) to post.
Austin
Austin
Hello everyone. If anyone ever needs Getty Design Parts, I am a "dealer." They have quite a few nice pieces for the 996-based cars.
- Mike Mitchell
Porsche Racing Club #4 (www.porscheracingclub.com)
Fremont, CA
- Mike Mitchell
Fremont, CA
