996 GT2/GT3 Forum 1999-2005
Looking for PN # for GT3 and GT3 RS Springs
Old 12-31-2004, 02:53 PM
cosmos
cosmos's Avatar
Received 1,120 Likes on 620 Posts
Question Looking for PN # for GT3 and GT3 RS Springs
I am looking for the part numbers for the GT3 RS front springs and the number for the rear springs. Are both front and rear different than the Standard GT3?
Also anyone have a picture or diagram of the front springs.
Thanks,
Old 12-31-2004, 04:40 PM
Viken
Keeper of the Truth
Viken's Avatar
Originally Posted by cosmos
I am looking for the part numbers for the GT3 RS front springs and the number for the rear springs. Are both front and rear different than the Standard GT3? Also anyone have a picture or diagram of the front springs.
GT3 Front Spring: 996.343.531.95.504
GT3RS Front Spring: 996.343.531.97.504
GT3 & GT3RS Rear Spring: 996.333.531.95.504
Old 12-31-2004, 04:46 PM
cosmos
cosmos's Avatar
Ok, so the rears are the same. Cool, I am going to upgrade just my front springs to RS springs.
Old 01-01-2005, 07:27 AM
Mr. C4
Mr. C4's Avatar
Cos,
Why? I wouldn't play around with spring ratios without correct shock valving.
Ciao,
Johannes E.
Old 01-01-2005, 03:06 PM
cosmos
cosmos's Avatar
The RS springs are only 13% stiffer then the GT3, the spring is also progressive not linear. I dont think the 13% is going to matter much.
Old 01-01-2005, 10:12 PM
gtdrei
gtdrei's Avatar
I think Cos is onto something here. The MKII front spring rate is 228lbs, rear 540. Thats a very large differential which could be one of the causes of the 'porpoising' phenomenon on bumpy roads, overall bumpy road instability, and understeer. Besides, it's not an expensive experiment, if it fails.
Robin
Old 01-01-2005, 10:56 PM
Greg Fishman
Greg Fishman's Avatar
Adding spring rate to the front will cause the car to understeer more.
Old 01-01-2005, 11:15 PM
Viken
Keeper of the Truth
Viken's Avatar
Where did you get those spring rates from? The front is clearly softer than it really feels and the rear is a tad stiffer. My car doesn't feel anything like it might have such a huge differential.
Old 01-02-2005, 01:29 AM
gtdrei
gtdrei's Avatar
Viken,
Porsche Club Panorama 9/03. Front 40 N/mm linear springs, Rear 95 n/mm progressive springs. Based on my math, which has never been good, and some help from a few conversion sites, the formula is n/mm X 5.71=ft/lbs. Which delivers the results I posted. Let me know if i'm wrong.
BTW, the same article claimed spring rates for the Cup car as Front 240 N/mm with 60N/mm helpers and Rear 260 N/mm with 60mm helpers. (no progressive springs )
Robin
Old 01-02-2005, 04:42 PM
cosmos
cosmos's Avatar
Default Adding spring rate to the front will cause the car to understeer more.
Yes, you are correct, however there is enough adjustablity in the swaybars to rid the car of whatever understeer the stiffening of the front may cause. The sways can not fix the rebound or compression that can IMO be fixed by stiffer springs.
The car has serious front end issues and stiffer front spings are the only way to cure those issues.
Old 01-02-2005, 07:17 PM
gtdrei
gtdrei's Avatar
Default Spring conversions
Sorry, my bad, the conversion is N/mm to lbs/inch. The factor used here and some other places was N/mm X 5.7 = lbs/in. Here's one of the sites I enlisted for help
Spring Conversions
Old 01-03-2005, 05:02 AM
Mr. C4
Mr. C4's Avatar
I would have thought that Porsche would have sorted any such issues, perhaps your car just needs a proper wheel allignment and corner balance.
It get's very scientific the day you start playing around with the GT3 chassi components (trust me, I know) and the end result might not be any better and you will find that the stock components work best but with a more track oriented chassi set-up. = all expensive parts in the bin.
I would personally not go down the route of changing chassi components unless the car spends 99% of it's time on a track and is being trailered to and from the track.
Ciao,
Johannes E.
Old 01-05-2005, 12:38 PM
Biker
Biker's Avatar
What about the 05 GT3, which is has softer springs (in the USA), are these cars equipped with different shocks?
Old 01-05-2005, 01:12 PM
Sloth
Sloth's Avatar
Whats with the softer springs on the 05 GT3 for the USA? I had not heard that one before...
Old 01-05-2005, 07:51 PM
gtdrei
gtdrei's Avatar
Default Softer Springs
Is this a fact or urban legend ? can anyone point me to where this is documented ? What's the part # for the 'softer' springs, and what's the new spring rate ? Linear, or progressive ? I have heard that there are springs with a '993' part #, but can anyone confirm ?
Robin
Quick Reply: Looking for PN # for GT3 and GT3 RS Springs
