Looking for PN # for GT3 and GT3 RS Springs
Keeper of the Truth
Originally Posted by gtdrei
Is this a fact or urban legend ? can anyone point me to where this is documented ? What's the part # for the 'softer' springs, and what's the new spring rate ? Linear, or progressive ? I have heard that there are springs with a '993' part #, but can anyone confirm ?
Interesting, even more so if they are actually 20% SOFTER than the 996 numbered spring, especially since it's been confirmed that the GT3RS springs are 13-15% STIFFER. I'm having trouble following why this 20% decrease in spring rate is an improvement....
Cos, when you take your 993 springs off can you run a spring rate test ? inquiring minds want to know.
Robin
Robin
Originally Posted by Mr. C4
I would have thought that Porsche would have sorted any such issues, perhaps your car just needs a proper wheel allignment and corner balance.
It get's very scientific the day you start playing around with the GT3 chassi components (trust me, I know) and the end result might not be any better and you will find that the stock components work best but with a more track oriented chassi set-up. = all expensive parts in the bin.
I would personally not go down the route of changing chassi components unless the car spends 99% of it's time on a track and is being trailered to and from the track.
Ciao,
Johannes E.
Ciao,
Johannes E.
PCH,
What I was tring to say was that there are chassi components available other than the factory parts that work better for track only use and if the car is fitted with these components, I wouldn't recommend driving it on the road, I would rather use a trailer.
Ciao,
Johannes E.
Ciao,
Johannes E.
PCH,
Ciao,
Johannes E.
Ciao,
Johannes E.
IMHO, replacing the shocks with an adjustable such as JRZ, Moton, or Ohlins can not be a bad decision, street, track or dual use. I've driven a GT3 that has Motons and it was much improved over stock.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Robin
Robin
