Caster Adjustment
I have seen different caster settings posted on the forum. My car is suffering from turning to the left when you lift off the throttle. My original car setting had caster set to R.7.* and L. 7.7. After a recent alignment the caster was R.7.8 and L. 7.4. This is within the Porsche 'spec', but I am concerned that it is a problem.
I have been told that the caster is NOT adjustable.
Is caster adustable on these cars? HOW? Would a difference in the caster cause the car to rotate left after lift off of throttle?
Thanks!
Thanks!
Does your car pull/rotate to the right when you get on the throttle...? From my experience, when the car pulls left or right that's usually a problem with the front end, when it wants to rotate that can be a rear-end problem.
It is more of a rotation to the left when going straight. However, when turning, it is as if the car wants to continue to turn on its own. It is as if you have to fight (not quite that bad) the car from turning on its own. I am taking the car to have it aligned again tomorrow and fully checked. (it has been aligned 3 times in the last 2 weeks by different people. Porsche dealership and local race/tuning shop. I have a track event at Carolina Motorsport Park this weekend and I want to get this sorted before the event - obviously!
One opinion is that something may be bent in the rear right suspension. After going through this more with Porsche - they said that it would not align properly if something was bent and that that was more of a tendancy with the 993's. The only other difference is that I moved the sway bars from one setting from loose to one setting from tight on the front and rear.
Any ideas would be very helpful.
Keeper of the Truth
I don't think caster has any effect on what you're experiencing. It is merely a function of how quickly the steering wheel returns to center. What you are experiencing may be a result of faulty toe at the back, but your alignment specs above don't show that. Your left to right camber isn't matching too well, but I doubt that makes a difference in this case. So, either your alignment went off after you had it done, or you may have a tire that's not consistent with the rest. Sometimes a shifted belt within the rubber can cause strange things like that.
