Steering questions for folks with GT3's
Hi, I had a couple of quick questions about the steering of the 996 (2004) GT3, I have heard that the steering has less turns lock to lock than a regular 996, is this true?
If so how responsive is it compared to a regular 996, is it slight or a big improvement?
One more thing, I guess the steering rack itself externally is no different than a regular 996, just a new internal pinion and rack?
Thanks folks!
Chris
Thanks folks!
Chris
Keeper of the Truth
The steering ratio and the number of turns are identical on all 996 cars. However, the steering on the GT3 is quicker mostly due to a bit more aggressive camber and toe settings.
Ratio: 16.9:1
Turns (lock to lock): 2.98
Ratio: 16.9:1
Still plays with cars.
Viken is (as always) correct. One other factor is the tires. The Michelin PS II have stiff sidewalls and that also improves response to steering inputs.
Rgds,
Rgds,
Rgds,
Rgds,
Jack - soft, compared to what? The contis that come on a regular 996? The question was why does a GT3 turn in faster than a normal 996. The PS II is softer than a Cup but they are very high performance for a street tire.
Rgds,
Rgds,
Rgds,
Rgds,
As to why the GT3 turns in faster lap times than the normal 996, I think there is more too it than just tires.
I'm with Jack, PS2 sidewalls are soft, too soft for a car of GT3 caliber. A lot of people's initial experience with PS2s has been driving the GT3, it's easy to see why they'd think the tires are exceptional - they're not, it's the car.
Guys, we've lost the thread. The original question up above was regarding the fast steering response of the GT3 compared to a regular 996. The poster wondered if the steer ratio was different. Viken responded with "no they are the same" and suggested that alignment settings have something to do with it.
I added that the PS2 may also be a factor (implied compared to a regular 996 with one of the OEM tires. I am not comparing the PS2 to a Corsa or Cup, but compared to regular 996's which around here seem to come mostly with Conti's the PS2 does have sharper response. Does that explain my post? Sorry if I spread confusion, there's enough of that around here already
