Just a thought with 997?Drag coefficient
Keeper of the Truth
Originally Posted by Karl S
The wider track has been mentioned in the PAG official press releases and some of the magazine reviews of the 997 quoted the exact numbers. I believe the rear track is an inch and a half wider than the 996.l
Front track:
996 with 18" wheels/tires: 57.70 in
GT3 with 18" wheels/tires: 58.50 in
GT3 Cup with 18" wheels/tires: 59.70 in
GT3 RS with 18" wheels/tires: 61.50 in
997 with 18" wheels/tires: 58.50 in
997 with 19" wheels/tires: 58.50 in *
Rear track:
996 with 18" wheels/tires: 58.30 in
GT3 with 18" wheels/tires: 58.90 in
GT3 Cup with 18" wheels/tires: 62.20 in
GT3 RS with 18" wheels/tires: 62.20 in
997 with 18" wheels/tires: 60.40 in
997 with 19" wheels/tires: 59.70 in *
* 997 Carrera S comes standard with 19" wheels and tires
Still plays with cars.
Hmm how much wider if the Cayenne V8 than the flat six?
Keeper of the Truth
Originally Posted by cosmos
What makes the GT3 Cup and RS trackes wider? Do they have different size wheels with different offsets?
Keeper of the Truth
Originally Posted by macfly
Is the RS track wider due to both control arms and offset, or just one or the other?
Keeper of the Truth
Originally Posted by Bill - Chicago
Viken - is the GT3 cup quoted above an 04. If so do you know if the specs are different from an 03.
Keeper of the Truth
Also what are the offsets and the wheel sizes of the cup car? Can we fit those sizes on the street car?
Actually the wheel centers are aluminum, magnesium centers are available from BBS but not from Porsche. Mag centers are illegal in the stock Cup classes in PCA but are often used in other series such as Grand Am. The wheels for the 2004 cars are:
front
GT3 street - 8.5J x 18, offset 40
GT3 Cup - 9J x 18, offset 46
rear
Gt3 street - 11J x 18, offset 63
GT3 Cup - 11J x 18, offset 59
As Viken noted, the wheels are set up for center locks but they can be drilled for use with studs, which is required in Grand Am (center locks are illegal in the SGS class for some reason). The Cup cars are actually delivered from the factory with rain tires only. You can then buy whatever type of track tire you want, slick, DOT R, etc.
front
rear
Received 1,223 Likes
If I was to order wheels from Fiske, or HRE, what size and off set would I go with? Can I go with Cup car sizes front and rear as well as offsets or will I have problems with clearence? Also what size tires doI run?
Keeper of the Truth
Old habits die hard
I guess it is years of M3 driving that has me in the mind-set that wider fronts is better. I really like that 9" front option of the Cup car, with the 11" rear.
I had a set of Fikse FM-10 track wheels for my 996. The fronts were 9" and I was able to run a 245/35/18 tire with no rubbing. A competent Fikse dealer should be able to set you up with a 9" wheel with the proper offset to fit the GT3 if you really want them.
Karl
Karl
