Weird Durametric Readings forMy Cams
I finally got my Durametric working and playing around I am a bit miffed by the camshaft position readings. See below. Thes remain steady at the values seen, regardless of engine RPM.
Is this expected?
Is this expected?
Im pretty sure the deviation is a sampled and smoothed reading so it should stay the same. Im not sure what the durametric calls it but my scanner call it "actual cam value" that gives me the vario advance in real time.
