4.0 LWFW and clutch part numbers
I'm sure this is available somewhere here, I did a search and could not seem to locate anything recent/definitive. Sorry in advance if this is user error on my part!
I bought the Sunset parts kit did the 4.0 conversion about 35,000 miles ago, I just started getting a mechanical 'clunking' on the clutch.
Not sure what the problem is but would like to have parts at hand/readily available when I open it up to see what's broken. Will of course install a new clutch while I'm at it, it must be worn some at this point.
Thanks in advance.
Matt
Thanks in advance.
Matt
Here's another that I found.
997GT3RS 4.0 clutch
997GT3RS 4.0 clutch
- 964.102.239.81 LWFW
- 964.114.143.31 Ring gear
- 928.102.151.01 FW bolts (9x)
- 931.102.111.02 Pilot bearing
- 997.116.013.92 Clutch disc
- 997.116.027.91 Pressure plate
- 900.067.103.01 Pressure plate bolts (9x)
- 950.116.813.30 Guide tube
- 999.270.070.02 Guide tube bolts (2x)
- 944.116.080.01 Release bearing
Thank you! Will try to cross-reference to the 4.0 RS PET and see what's possibly new or superseded.
If anyone else has done this recently and has confirmed part numbers, don't be shy
Cheers
Matt
Cheers
Matt
