Dancing Oil Pressure - Normal?
Hey all,
Today when my car was up to temp my oil pressure was dancing around a bit. Is this normal? I had a low oil pressure warning earlier in the day (for 1 second then went back to normal). Maybe my oil sender unit is on the way out?
The senders r known to fail often. Its sounds like yours is on the way out. Only why to really verify is to graph against a secondary semsor. Most poeple just swap it out. Its reachable from the top, 19mm wrench and i think 7mm for the wire post nuts.
SF944 (04-06-2023)
black04 (04-08-2023)
