GT2 and GT3 owners of PCCB do you use it or swap brakes?
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
The issues of burning up $14,000 dollar rotors come to my mind. Do any of you use aftermarket cast rotors for street use in order to avoid a costly replacement of these brakes? Plus, what are your thoughts on the brakes? Do you like PCCB? has anyone tracked with them? How long do they hold up with vigorating heat conditions?
Andy
Andy
Yes this has been discussed at great length. The short answer is, they don't seem to hold up well under heavy track use and may tend to get a little noisy on the street. If you have an option I would recommend against getting them but if the car aleady has them there are steel brake options out there and hopefully soon there will be a steel rotar available that will be a direct replacement for the PCCB rotar
For street use, the ceramics will last the life of the car. My bet is that PCCB rotors will come down significantly in price in the future, as Porsche starts fitting these brakes on more cars in commng years. Dealer retail pricing for reconditioned ceramics is at $4k vs $1k for new steel rotors.
Originally posted by Jack
[B]Unfortunately, neither does the cast iron rotor setup hold up well under heavy track use. Many have reported the need to replace the steel rotors after ~ 1000 track miles and less -- Bob R. got 9000 track miles out of his PCCB's. The real problem with the GT2/3 cars is inadequate brake cooling under heavy track useage conditions.
Fuse 24 Assassin
Fuse 24 Assassin
ok I did some searching and I came across a topic to get steel rotors for the car. Who sells aftermarket steel or iron rotors for GT2s??? Evo Motorsports just sells a 15" Brembo kit and S-Car-Go only does engines...
Andy
Andy
Originally posted by bob_dallas
I'm afraid I have to disagree here. I can't and won't speak for the carbon ceramic rotors since I don't have direct experience with them but the iron rotors work fine. Performance and longevity have met expectations. I'll probably go with slotted rotors next so I don't have to worry about the holes clogging up (which will significantly degrade performance and longevity as with any iron rotor) but that's about the only reason. I'm just one person but there are a lot of people on here that track GT3s with the iron rotors - if there were "many" failing I think we would have heard about it.
I hope you don't experience "early" deterioration of your steel rotors. If it's not too much trouble, please report back after you have 1000-1500 track miles on the stock setup. I do think there's a cooling issue which will affect all GT2/3 rotor longevity under extreme track conditions. I also agree that the GT cars will benefit from a 2-piece aluminum floating hat, slotted rotor setup -- less unsprung weight, better dissipation of heat and no holes to get clogged.
Yeah, I'll just leave it at that - I'm happy so far and they've met my expectations but wouldn't complain with something better... For the record, I don't keep track of track miles but I must be pretty close to or past the 1k mark by now. I will say that I can't emphasize enough what keeping the holes cleaned out does for performance or longevity...
Confession time!
I know this is pretty ****, but I confess to having just got a log book. Since getting the MPSC's, and needing to keep track of their heat cycling, and the arrival of my Race Tech DL1 from the UK I decided to go the whole hog. I'd been keeping a rough log of track - road miles on my original tires, so can give you an instant review.
FWIW, here is my info.
MPS2 - OEM Pads;
3,600 miles, includes 1,000 miles run in below 5K rpm, and 1,350 at the track.
(big Willow, best average 87mph)
MPSC - Pagid Yellow RS-19
420 miles, 235 at the track.
(big Willow, best average 89mph)
Car total 4,046 miles.
OEM steel rotors showing only very slight radial cracks, but they have started. Not sure if it is a linear or logarithmic deteriation from here. Brembo, Alcon, hurry up with those slotted floating disc sets for our calipers!
MPS2 - OEM Pads;
Great work, Andrew. Keep the data flowing. Once the stress cracks began showing up on our front rotors, they seemed to spread at a more exponential rate.
My friend at Brembo thinks they will have the 2-piece floating hat rotors that will work with the stock GT3 calipers by year-end -- perhaps a bit sooner.
Jack:
FWIW,.....I have Alcon racing slotted, full floating rotors and billet, anodized hats right now for the front of your car.
These are 360mm x 34mm and FAR more durable than the OEM stuff.
Fuse 24 Assassin
Fuse 24 Assassin
JMcD I agree with you when it comes to using them for street. It's just too expensive to bring to the track, unless you're in it for points and like outbraking other cars into corners. The GT3s and GT2s with PCCB would bring shock and awe with their braking!
Andy
Andy
