Rear toe alignment with spherical adjustable toe arm
How should I adjust my alignment for rear toe when replacing the rear toe arm with an adjustable unit that compromises of an inner spherical bushing and lockout eccentric bolt kit? For example, do I scale back on the amount of toe in I would've spec'd in now that the spherical bearing provides less deflection, and if yes, by how much? Appreciate any insight.
Thanks!
Thanks!
I used tarret locking plates for the bolts and i just adjusted the link. Its safer because the eccentric bolts sometimes slip.
What my limited knowledge of toe is that it is basically a static adjustment. So I would go with standard specs
Sorry misread your post. Agree with above, stock settings for street driving
Thanks!
Thanks!
