how much will front camber change if I lower the front 1/2"
I know it will add neg camber approx how much.
Do i just lower the lower the spring perches. I see theres also a ring on the bottom of the strut where it connects to the spindle. What does that do? I have a toe and camber gauge. thanks
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Depending on how much bump-steer GT3's have, you may get an unfavorable toe change as well..
I would think GT3's are pretty sensitive to toe's and cambers...
Still plays with cars.
Lowering a half inch will not add a lot of negative camber - may 0.2 degrees. I have been told that GT2 and GT3 are very sensitive to ride height although I can't see how lowering it in the front could make things nasty. The GT2 is nearly 1/2 inch lower in front that the GT3 from the get-go.
Best,
Best,
Keeper of the Truth
It appears that US bound GT3's (and, *maybe* even 2004 GT2's) are 10 mm higher in front. If you really want to lower yours, just go by the factory specs and have the car re-aligned and corner balanced accordingly. Height specs are:
Front: 115 + 5 mm (115 to 120 mm)
Rear: 128 + 5 mm (128 to 133 mm)
Viken, as always I defer to you on specs ):-)
Canadian GT3's may be different. When I had mine aligned and corner balanced my front ride height was 118 mm and the rear was 128.
Regards,
Regards,
Keeper of the Truth
Basic Site Sponsor
Basic Site Sponsor
Where are you measuring ride height from?
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
