RS Poseur-look continues
I sealed the gaps between the scoop and the decklid by putting a high-heat neoprene foam strip around the edge (sticky on one side, against the scoop), that way I can easily remove it if needed.
4porsh (10-05-2020)
Looking at where you're headed we could end up with twins. I also have a black CF RS wing - though it's not currently mounted. Years back I got a NLA factory look GT3 spoiler in CF that has a Gurney lip molded into the rear edge. Unfortunately it was already in primer so I had it painted body color. It's a VERY subtle modification. I rotate the wing on now and then. I don't have the scoop you just added. Are you considering a side graphic with matching color wheel centers - like black/black?
The tape seems to have quite a bit of "sticktion", I'm going to risk it for a bit.
Is that a factory RS bumper? I had heard they were quite expensive. When I bought my car the original owner had the bumper cut out like an RS. I'm assuming cut out because it has been off the car and is a factory bumper. I always assumed he just had it cut like an RS and put in the grills.
No wat to "prove" factory RS AFAIK.
I'm not a fan of black graphics or wheels on a yellow car, so will stick with either silver or no graphics.
I'm still figuring how I might add yellow accents to silver wheels ala RS wheels.
I just plasti dipped these but yellow plastidip is wrong hue.
Cheers
Craig
The lip is very subtle and the wing shape is otherwise stock looking. It was a prototype wing that I received as part of another transaction. I don't know if they ever went into production.
I tried to match the lettering font to the GT3 (based on the shape of the "T") but probably need to use slightly shorter lettering.
